ᐅ The Malm nightstand wobbles slightly – when is it worth repairing?
Created on: 27 Oct 2018 14:23
bella38Hello everyone,
I have had an Ikea Malm nightstand for a while now, and I’ve noticed it wobbles slightly. The wobbling isn’t severe but is noticeable. Since I’m not sure whether it will get worse over time or if there are simple repair options, I’m wondering: When is it worth repairing a Malm nightstand that wobbles a bit?
I would like to know how to best determine if a repair is worthwhile due to material fatigue, loose screws, or structural damage, or if it might be better to consider replacement right away. The nightstand is about three years old and is mainly used as a bedside table.
Maybe someone has experience with the stability of the Malm series, tips for repairing it, or opinions on when it is more cost-effective and sensible to just buy a new nightstand.
Thanks in advance for your thoughts and advice!
bella38 schrieb:
When is it even worth repairing a Malm nightstand that wobbles slightly?I think this is somewhat of a philosophical question. If a piece of furniture wobbles, it usually indicates either quality issues or wear and tear – but shouldn’t you question whether it’s better to replace Malm products altogether?
Let’s be honest: Ikea furniture is designed for quick, affordable solutions. If something wobbles, repair it? Why not just buy new? The effort often doesn’t match the benefit. Of course, environmental considerations are a different matter, but practically speaking?
I say: if the nightstand isn’t falling apart and you don’t experience discomfort while using it, just leave it! Repairing usually only makes sense if the piece is higher quality or significantly more expensive.
The wobbling of a bedside table might not seem like a big deal at first, but as someone who often repairs furniture, I understand that it can cause some uncertainty.
That’s partly true, but sometimes it’s also about how comfortable you want to feel in your own home. A wobbly bedside table can be quite annoying and may lead to further damage if screws continue to loosen.
A small investment in repair can therefore be worthwhile, especially if you like the bedside table and it wasn’t expensive. If you use it regularly, its condition can often be improved with a few simple adjustments.
LIELCHEN schrieb:
I say: If the bedside table isn’t falling apart and you don’t experience any pain using it, then just leave it alone!
To evaluate whether it is worthwhile to repair a slightly wobbly Malm bedside table, a systematic approach should be followed:
1. Cause analysis: Common causes are loose screws, uneven flooring, or material fatigue.
2. Screw inspection: Are all fasteners at the joints still secure and free of rust damage?
3. Base foot check: Are the adjustable feet intact, especially the rubber grips?
4. Material test: Are there visible cracks or swollen areas in the wood or particleboard material?
If a simple adjustment solves the issues in the first three checkpoints, repairing is definitely worthwhile. Otherwise, replacement might be more beneficial.
It is important to know that the Malm nightstand is primarily made of particle board. These tend to become mechanically weaker over time, especially at screw joints.
After three years of normal use, the wood often begins to show early signs of fatigue, especially if moisture has been present. In such cases, repairs using special wood glues and fillers can help— but only if there are no major cracks. If the nightstand wobbles in several places and not just one screw is loose, a repair is usually not sustainable.
bella38 schrieb:
The nightstand is now about three years old and is mainly used as a surface next to the bed.
