ᐅ How can I repair Malm furniture without professional knowledge?
Created on: 8 Apr 2024 18:12
anjome45
anjome45
8 Apr 2024 18:12
I have a Malm bed and a Malm wardrobe from Ikea at home, both of which have unfortunately suffered some wear and tear due to moving and rental activities. Since I am neither a carpenter nor very experienced with DIY, I want to try repairing the furniture as independently as possible. I’m mainly interested in methods and materials that allow for fairly neat repairs to stability and appearance, even without extensive technical knowledge.
Specifically: How can I secure loose screws, touch up small dents in the wood or the finish, and possibly fix squeaky mechanisms? Are there simple tools or aids that I should definitely have?
I look forward to tips, tricks, and an idea of the effort and time involved. Thanks in advance!
kulau
8 Apr 2024 18:45
Hello anjome45,
Your question is very interesting and shows that you have a good understanding of the challenges involved in repairing Ikea furniture. Malm furniture is mainly made from particleboard and decorative laminates, which means that the stability often depends on the type of joints and fittings used.
Regarding loose screws: the usual trick without special adhesives is to fill the screw hole with a small piece of wood or a toothpick combined with wood glue, so the screw grips tightly again. It is important to let the area dry before re-screwing.
Small chips in the finish can be well repaired with special wax fillers or wood repair markers available at hardware stores. For paint damage, thin layers of fine spray paint that match the color work well.
Mechanisms (such as drawer slides) usually become smoother again after cleaning and applying graphite powder or silicone spray. Feel free to be more specific about your furniture and which parts are affected.
For tools, I recommend at least a good cordless drill, a set of hex keys (Allen wrenches), fine sandpapers, and wood glue.
How much time you need? Depending on the damage, a few hours to several days is realistic, especially if the repair is intended to be thorough and well done.
Lorukeo
8 Apr 2024 19:06
In addition to kulau: For your purposes, it makes sense to proceed systematically. Step 1: Assess the damage (loose connections, visual defects, mechanical issues).
For loose screws, if the simple wood insert trick is not enough, you can also use small wooden dowels that you pre-drill to ensure a secure connection.
For surface repairs, there are well-defined repair kits with color tones specifically recommended for Ikea furniture to minimize color differences.
Regarding "without expert knowledge": It is important not to use too many different products at the same time to avoid confusion. Document the steps so that you can respond effectively if problems arise.
Missing screws or damaged fittings should ideally be replaced with original parts to prevent stability issues.
GiRoyce
8 Apr 2024 19:22
Hello anjome45,
your approach is absolutely sensible. Especially with furniture like Malm, which often consists of veneered particleboard, damage to edges and corners is a functional concern.
For minor scratches: there are wax repair kits with wax surfaces that can be selected based on the Ikea color palette. These are easy to use and look quite natural – perfect for beginners.
I also recommend always starting with soft cloths and a mild cleaning agent before doing any repairs. Cleanliness is the foundation for later gluing or touch-ups.
Regarding screws: if you notice the wood is becoming loose, you can either work with some wood glue and a small wooden wedge or use special repair fillers. This often restores sufficient stability to the construction.
For drawers or moving parts, WD-40 or silicone spray often help to get squeaky mechanisms running again – but please use sparingly to avoid attracting dust.
anjome45
8 Apr 2024 20:03
kulau schrieb:
Regarding loose screws: The usual trick without special adhesive is to fill the screw hole by inserting a small piece of wood or a toothpick with wood glue.
Okay, that sounds doable. What is the best way to insert the wooden piece? Should it be very thin? And if I fix it with wood glue – how long does the drying time need to be before I can screw it back in?
Lorukeo schrieb:
For loose screws, if the simple wood fill trick isn’t enough, you can also use small wooden dowels that you pre-drill.
What is the correct procedure if I want to use wooden dowels? Do I need special tools, or can I manage with a regular drill?
Thanks for the initial tips, I want to take it slowly and carefully.
Dilen
8 Apr 2024 21:15
Regarding screw fastening, I can add the following:
Screws usually loosen because the chipboard material wears out over time due to constant pressure and movement. If you want to use wooden dowels, a drill press stand for the drill is recommended to ensure very precise vertical drilling. If you don't have one, you need to work very carefully by hand to avoid drilling at an angle into the material.
The procedure:
1. Clean the old hole thoroughly and remove dust.
2. Choose a drill bit according to the dowel size.
3. Coat the dowel with wood glue.
4. Lightly tap the dowel into the hole and let it dry (at least 12 hours).
5. Then insert the screw into the dowel.
If you only have simpler tools, suitably cut toothpicks with wood glue also work. The advantage is that they are smaller, more flexible, and dry faster (about 1 to 2 hours).
Important: Do not tighten the screws too much, or you will damage the repaired area.
