ᐅ How can I repair Malm furniture myself without professional help?
Created on: 15 Apr 2020 09:17
kihanspete
I own several Malm furniture pieces from Ikea that have started to wobble or show minor damage in some areas over time. Since I’m not a big fan of hiring professional furniture repair for every small issue, I would like to try fixing my Malm furniture myself as much as possible.
My specific question is: How can I repair Malm furniture on my own when, for example, drawer slides are sticking, screws have become loose, or the wood is chipped on some edges? What tools and materials would be recommended for these repairs, and are there any particular construction features of the Malm series I should be aware of?
I would really appreciate any experiences, tips, or advice on mistakes to avoid!
TARAON
15 Apr 2020 16:43
Hey! 🙂 If you’re assembling Malm furniture yourself, always remember: Being well prepared is half the battle!
Personally, I love having my small toolbox with screwdrivers, a file, and also lubricants that not only fix things but make the process enjoyable – it actually makes screwing together fun. 😉
A quick tip: When you put the parts together, make small marks with a pencil – that way, you can more easily find your way back when disassembling, you know? Especially with Ikea furniture, it’s a handy trick. Good luck!
kihanspete
16 Apr 2020 08:05
Raymond schrieb:
If drawer slides stick, first check if dirt or debris is caught in the track.
That makes sense! There was actually a little bit of dirt on the rails.
jelite schrieb:
Fill worn-out holes with wooden dowels or toothpicks plus wood glue.
I didn’t know that, sounds like a practical solution. I guess I need to get some wood glue and toothpicks.
Layla schrieb:
I ordered a small repair kit on Amazon: wood filler, sandpaper, furniture wax.
Can anyone recommend a specific product? That would be really helpful! Thanks in advance for the tips :-)
jelite
16 Apr 2020 10:56
Sure, I often use "Pattex Repair Express" for wood filler work; it dries quite fast and can be sanded smoothly.
For furniture wax, "Osmo Pflegewachs K" works very well; it doesn’t leave a strong shine and suits lighter surfaces like Malm.
Important for sandpaper: grit around 180 to 240 for fine finishing – avoid coarse grits, as they can unnecessarily damage the surface.
If you want to avoid fingerprints, I recommend work gloves, which make many tasks easier.
ralfsau
16 Apr 2020 11:48
kihanspete schrieb:
Thanks already for the tips :-)
Titebond wood glue is very good. For wood filler, it’s better to choose one in a wood color rather than white. That makes it look more natural.
GLALEO
16 Apr 2020 18:23
It’s great that you’re gathering so many tips! I’ve been repairing my Ikea furniture myself for years and can only confirm: patience plus the right materials are worth their weight in gold!
Especially the tip about using silicone spray on the drawers is spot on – I once used a spray that was greasy and ended up with more trouble. 😉
Also: don’t get discouraged! Small dents and scratches can be fixed quickly, and you get better with every repair. Good luck to all the DIY enthusiasts here!
taudi
17 Apr 2020 09:02
When I repair Malm furniture myself, I usually follow this process:
- Analysis: Identify the exact problem, such as a loose screw, a drawer not sliding properly, or surface damage.
- Preparing materials: Gather glue, filler, screws, sandpaper.
- Repair: Stabilize screws first (wood glue + toothpicks/dowels), then clean the drawer slides and treat them with silicone spray.
- Surface: Fill scratches with wood filler, then sand and, if needed, seal with furniture wax.
The key is to wait patiently after each step until everything is fully dry. This ensures the repair lasts in the long term. Also, never use force, as this tends to cause more damage than it helps.
Feel free to ask if you have any questions—I have quite a bit of experience with this.
