ᐅ The Malm nightstand wobbles slightly – when is it worth repairing?
Created on: 27 Oct 2018 14:23
bella38
I have had an Ikea Malm nightstand for a while now, and I’ve noticed it wobbles slightly. The wobbling isn’t severe but is noticeable. Since I’m not sure whether it will get worse over time or if there are simple repair options, I’m wondering: When is it worth repairing a Malm nightstand that wobbles a bit?
I would like to know how to best determine if a repair is worthwhile due to material fatigue, loose screws, or structural damage, or if it might be better to consider replacement right away. The nightstand is about three years old and is mainly used as a bedside table.
Maybe someone has experience with the stability of the Malm series, tips for repairing it, or opinions on when it is more cost-effective and sensible to just buy a new nightstand.
Thanks in advance for your thoughts and advice!
ladali
27 Oct 2018 17:30
If you decide to go for a repair, I recommend the following approach:
- Completely loosen the screws and reinsert them, if necessary combined with a suitable wood glue or dowel adhesive.
- For loose joints, you can install metal brackets for reinforcement.
- Felt pads or furniture glides under the feet prevent micro-movements on smooth floors.
If these measures don’t work because the wood at the connection points is already heavily damaged, then the repair effort is no longer worthwhile.
V
vinpau
27 Oct 2018 19:04
Hello bella38!
I had a similar issue with my Malm nightstand – it was a bit wobbly, which really annoyed me. But with a little tightening of the screws and some wood glue, I was able to fix it myself, and now it’s completely stable again! 🙂
I think if the wobbling bothers you, especially with furniture you use often, it’s definitely worth repairing. Ikea furniture is designed to be easy to fix on your own. Plus: you save money and help the environment!
blaki
27 Oct 2018 20:10
vinpau schrieb:
I think if the wobbling bothers you, especially on frequently used furniture, then the repair is definitely worth it.
Absolutely! Tightening the screws a bit is like a free refresh for your furniture :-)
A few small tips: Always loosen the screws one at a time, not all at once, so the furniture doesn't fall apart.
And if you want to be extra careful, use a few drops of thread locker (thread-locking fluid) to slow down future loosening.
Just do this after work—it can even be fun—and there you go, your bedside table won’t wobble anymore, and you can sleep peacefully!
bella38
28 Oct 2018 08:44
Thanks for all the helpful responses so far!
I will check and tighten all the screws.
@pikin: Thanks for the tip about the particle board; I hadn’t considered that. It’s more like the wobbling isn’t limited to just one corner but can be felt in several areas when gently pushing. So I think material fatigue might also be a factor.
@blaki: Threadlocker sounds interesting. Do you have any recommendations for one that can be easily removed if I need to access it again?
I’m also thinking about adding metal brackets for reinforcement on the inside. Do you have any tips on how to install them without visible screws on the outside surface?
mifra
28 Oct 2018 09:33
Regarding screw locking:
There are medium-strength thread lockers (e.g., Loctite 243) that can be removed later with standard tools if needed.
Metal brackets are a good idea to improve stability. For a concealed installation, attaching them to the inside of the bedside table or possibly under the tabletop is recommended.
Drill holes should be made as precisely as possible and reinforced with appropriate wall plugs to avoid weakening the material further.
Avoid excessive force when screwing, as chipboard can loosen more quickly otherwise.
LIELCHEN
28 Oct 2018 10:11
bella38 schrieb:
I’m also considering whether metal brackets can be installed inside for reinforcement
One method I have tried is mounting the brackets on the inside with short, thin screws and then covering the visible edges with wood filler or paint that matches the color. This works surprisingly well.
Alternatively, you can use so-called L-brackets with rounded corners that blend in better.
Just make sure they are not too large or very noticeable, as that tends to look quite makeshift.
