ᐅ Are there any tools or methods to make Malm furniture more stable?
Created on: 13 Jul 2017 08:13
jonuloHello everyone, some time ago I bought a few IKEA Malm furniture pieces, but I’m not entirely convinced about their stability. That’s why I’d like to ask the community: Are there any proven tools or methods to make Malm furniture—especially dressers and drawer units—more stable in the long run? I’m not just thinking of minor reinforcements, but tips that actually make a noticeable difference in securing wobbly furniture without compromising the appearance. If anyone has experience or even workshop advice, I would really appreciate any suggestions.
That’s a really good question! 🙂 I once had a Malm dresser that became quite wobbly after a few years. My tip is to reinforce the furniture with additional metal brackets at the corners! You can get these brackets cheaply at a hardware store; they’re quick to screw on and make the whole structure much more stable. Adding a few drops of wood glue between the joints also helps everything feel much more solid!
So it’s definitely worth using these small aids – it was a real game changer for me! :-)
I can understand how annoying it can be when furniture is unstable and wobbles when you open the drawers. I’ve noticed that with Malm furniture in particular, the importance of securing it to the wall is often underestimated. Furniture that is firmly screwed to the wall is much more stable and secure, especially if there are children in the household.
Perhaps that could be a first additional step for you before using more advanced aids. How is your furniture attached to the wall?
By the way, I’ve also read about self-adhesive felt or rubber pads for the feet of furniture, which can help reduce slipping and slight wobbling. That might be worth trying as a supplementary solution.
There are several technical approaches to stabilizing IKEA Malm furniture, which can be effective depending on the specific issue:
1. Using sturdy metal brackets (approximately 40x40mm (1.6x1.6 inches)) to reinforce the corner joints inside the dresser. These can significantly increase torsional rigidity.
2. Replacing the original wooden dowels with metal connectors or screw bolts with nuts, which provide longer durability.
3. Carefully installing the IKEA wall mounting bracket is essential – many problems arise from screws being too loose or missing.
4. For extreme wobbling, adding a reinforcement board underneath the dresser (e.g., a plywood panel) can help distribute loads more effectively.
It is important not to overtighten screws to avoid damaging the material.
Making Malm furniture more stable? Shoes! 😉 I mean, if you really care about stability, the real question is how much money and effort you’re willing to invest. Malm is just standard furniture, not a designer premium product meant to last forever.
I think anyone having problems with wobbling should basically consider going for something else right away. Sure, you can tinker and screw things together, but in the end, it’s just a temporary fix—what’s the point? Just accept that Malm is nice and affordable, but if you need absolute stability, you’ll have to look elsewhere.
Of course, there are aids available, but they are more like treating the symptoms.
Connor schrieb:
Malm is standard furniture, not a designer premium product meant to last forever.That is true, but you also have to consider how common Malm is in households nowadays and that it offers decent quality for the price. Many people want to get the best value for their money.
I think it’s important to discuss alternatives or improvements as well, so those who choose Malm can still ensure safe use.
