ᐅ What guides are available for repairing IKEA Brimnes drawers?
Created on: 13 Jul 2017 09:12
tejuku
Hello everyone, I am currently looking into repairing IKEA Brimnes drawers. Specifically, I am searching for well-structured and easy-to-understand guides that explain how to fix common issues—such as drawers sticking, misaligned runners, or damaged drawer bottoms—in a targeted way. I am particularly interested in step-by-step instructions that address specific challenges related to this model and mention any necessary tools or replacement parts. Does anyone have experience or know of detailed guides, preferably with tips for making the process as simple as possible? I want to extend the drawers’ lifespan and avoid unnecessary replacements.
sonplo
13 Jul 2017 11:38
To stabilize the drawer bottom, I recommend using plywood sheets with a thickness of 6 to 8 mm (¼ to ⅓ inch). These provide a good balance between strength and weight. Common wood glue (photovoltaic panel adhesive) works well as it is strong and can be reversed for future repairs. It is important to cut the sheet cleanly before gluing and to remove dust from the glue surfaces. Alternatively, plywood can also be used, but make sure to pay attention to the correct thickness to prevent the drawer from sticking.
tejuku
14 Jul 2017 08:14
sonplo schrieb:
Common wood glue (such as photovoltaic panel adhesive) is suitable as an adhesive, as it is durable and reversible for future repairs.
Great, this information is very helpful to me. Perhaps also of interest: Are there any other tips or tricks to make guide rails more durable? Some tend to stick or jump slightly, which isn’t necessarily due to damage but more from wear and tear. I was considering oiling the rails or using silicone spray—any experiences with this would be great.
Samir
14 Jul 2017 08:48
Oiling is generally not recommended for Brimnes drawers, as wood particles and dust can combine with the oil and cause more dirt buildup in the mechanism. Silicone spray is a better option here. It creates a smooth surface on the metal parts and protects against corrosion. It is important to use the spray sparingly and, after application, open and close the drawers fully several times to remove any excess material. This noticeably extends the lifespan of the drawer slides.
tejuku
14 Jul 2017 09:12
Samir schrieb:
Silicone spray is more suitable here. It creates a smooth surface on the metal parts and protects against corrosion.
Thank you very much for the expert recommendation; I will use silicone spray. To further improve the drawers, I imagine that the screws on the slides might need to be checked and tightened if necessary. Does anyone know of a sequence or method to verify whether the slides are properly seated and how this affects the running quality?
neo59
15 Jul 2017 10:21
tejuku schrieb:
To further improve the drawers, I can imagine that the screws on the drawer slides might need to be checked and tightened if necessary.
Tightening the screws should indeed be done during any repair or maintenance, as they can loosen over time due to movement. It is important to preferably use a suitable screwdriver to tighten the screws evenly, taking care not to warp the drawer front by applying too much force. A practical approach is to first remove the drawer and tighten the slides individually. Then, reinstall the drawer and test its operation to make any necessary fine adjustments.
