ᐅ How do I repair Malm furniture after water damage?
Created on: 31 Dec 2021 08:13
Eleni55
Eleni55
31 Dec 2021 08:13
I have a few Malm furniture pieces from IKEA that were unfortunately damaged by water, especially at the edges and the feet. The coating is peeling off in some areas, and the wood underneath has swollen or expanded. I don’t want to completely dispose of the furniture but instead try to repair it properly.
My question is: What is the best way to repair Malm furniture after water damage? Which materials and tools do I need to treat the swollen areas, restore the coating’s appearance, and maintain stability?
Are there any special techniques you can recommend to reduce or eliminate swelling in the particleboard core? And how should I handle the damaged edges so the piece looks as close to new as possible?
I’m looking forward to practical tips and experiences!
BEMAU
31 Dec 2021 08:54
The issue with water damage in Malm furniture usually stems from the material used: particleboard with a thin melamine foil or coating. Once moisture penetrates, the board swells quickly.
For repairs, I recommend the following steps:
1. Drying: Make sure the furniture is completely dried out. All moisture must be fully evaporated.
2. Swelling: Slightly swollen areas can be smoothed with fine sandpaper (grit 220), while severe swelling may need to be carefully removed with a sharp knife.
3. Filler: Use an acrylic-based wood filler for any damaged spots; it sands well.
4. Edges: Repair edges with suitable edge trims or painter’s tape, then secure them with contact adhesive.
5. Coating: Applying a new, thin layer of spray paint or clear varnish can help protect against further moisture.
In general, even the best repairs on Malm furniture are only temporary solutions, as the material is not waterproof.
Parbo
31 Dec 2021 09:32
I would go one step further and examine the condition of the particleboard core more closely. In Malm furniture, MDF or particleboard is usually used, which significantly loses its stability when exposed to moisture.
My advice:
- First, carefully remove all swollen or soft parts of the particleboard with a fine utility knife. Be sure not to cut too deep to avoid further damaging the core material.
- Then, if the edges have severely loosened veneers or laminates, remove them completely, as proper repairs will be difficult otherwise.
- Next, apply a suitable wood filler or epoxy resin designed for wood repairs. Epoxy resin cures waterproof and prevents further swelling.
- After it has fully hardened, sand the surface (grit 180-220) and repaint.
- For newly applied edge profiles, you can use special thermofoil edges or self-adhesive PVC edges, as they are much more water-resistant.
- If you want the furniture to last a long time, I recommend completely replacing damaged parts or at least seeking a professional assessment.
One more question: Are the damaged areas on vertical or horizontal surfaces? How large are the affected spots?
Eleni55
31 Dec 2021 09:47
Parbo schrieb:
One more question: Are the surfaces vertical or horizontal? How large are the damaged areas?
Good question. In my case, it’s mainly the vertical edges and the bottom edges of the drawers that are affected, as well as the legs where the floor was damp. The damage is mostly on the lower parts, with areas around 5-10 cm (2-4 inches) in size, sometimes slightly swollen, sometimes just loose or damaged veneer. The surfaces themselves are generally still stable and not extensively damaged.
tarju41
31 Dec 2021 10:03
Use wood filler for small repairs, sand it down, and reattach the membrane with contact adhesive.
Make sure to keep the joists dry, otherwise they will swell again.
tolokau
31 Dec 2021 10:35
A simple step-by-step guide for repairing Malm furniture after water damage:
1. Remove all loose and swollen parts using a sharp knife or chisel.
2. Dry the piece of furniture over several days in a warm environment to eliminate remaining moisture.
3. Sand the damaged edge surfaces with fine sandpaper (grit 180 to 220).
4. Fill with special wood filler or epoxy wood filler, for example two-component, to achieve water resistance.
5. After curing, sand thoroughly.
6. New melamine foil can be problematic, so I recommend applying a thin protective coating with acrylic or wood varnish.
7. Stabilize edges with self-adhesive PVC edging or corner protectors.
Important: When working after water damage, remember that the furniture core swells quickly. Therefore, any preparatory cutting and sanding should be done carefully and in several stages.
