ᐅ Are there Malm furniture pieces that are suitable for outdoor use?
Created on: 25 Feb 2023 08:13
norbert70
Are there Malm furniture pieces suitable for outdoor use?
I’m interested in the Malm series from Ikea, specifically nightstands and dressers. Since I want to create a cozy lounge area on my terrace with modular furniture, I’m wondering if the Malm models are suitable for covered outdoor spaces. Of course, they are primarily designed for indoor use, but perhaps there are versions or special treatments available?
It’s important to me that the material is at least splash-resistant and can withstand occasional weather exposure. Does anyone have experience with whether the surface, such as the foil coating, is somewhat more resistant? Or is the risk of swelling and warping too high?
I would appreciate well-informed recommendations or alternative suggestions if Malm is not suitable for outdoor use.
chenValeri
26 Feb 2023 09:15
I would strongly advise against Malm Outdoor. The foil tears easily when wet, the panels absorb moisture, and the furniture becomes unusable.
It is better to choose furniture specifically designed for weather-resistant outdoor use.
gekira
26 Feb 2023 10:29
Regarding the situation: The Malm series is based on particleboard or MDF substrates with decorative foil coating. These materials are technically not water-resistant and have no impregnation. Therefore, damage caused by moisture, such as swelling and damage to the foil, is almost inevitable.
Additionally, temperature fluctuations are problematic because the panels expand and contract, which can lead to cracks or delamination of the surface.
For covered outdoor areas, there are coatings that can temporarily improve this, but they do not provide reliable long-term protection.
My advice: Choose furniture made from hardwood species (e.g., teak) or with special outdoor finishes. If you insist on using Malm, it should be used exclusively in dry indoor areas.
NOAHSAU
27 Feb 2023 11:02
Why are you so fixated on a piece of furniture that clearly isn’t meant for outdoor use?
Exactly. Anyone who says otherwise is just pretending to be a stylish improviser for garden furniture.
I don’t understand the trend of using trendy indoor furniture on the patio. Mall furniture is designed for the bedroom, living room, or hallway—not for areas exposed to wind and weather.
Really good outdoor furniture is not complicated and doesn’t have to be expensive. Save yourself the trouble.
norbert70
27 Feb 2023 12:17
I completely understand your points, don’t worry, I’m not planning to place a Malm dresser out in the rain.
I’m particularly interested in whether anyone has experience using a Malm dresser at least in a covered area, such as a terrace with a roof, where the furniture isn’t directly exposed to rain.
Maybe it’s feasible with occasional maintenance—otherwise, I’m open to alternatives and would appreciate any suggestions.
KUDAISY
27 Feb 2023 15:34
norbert70 schrieb:
I’m specifically interested in whether anyone has experience using oak at least in covered areas
In my opinion, the risk largely depends on the local microclimate. If the area is constantly humid and poorly ventilated, moisture can still penetrate even under cover and cause damage.
If the furniture only gets slightly damp occasionally but otherwise stays dry, protective measures (such as sealing or covers) might lead to positive outcomes.
Regular inspection of the surface and prompt repair of minor damage are crucial. Weak edges or torn membrane spots are especially vulnerable.
Summary: Possible, but not recommended if you expect versatility and long-term durability.
KNUTGI
27 Feb 2023 17:51
KUDAISY schrieb:
Possible but not advisable if you expect versatility and durability.
That’s exactly what I wanted to express with a bit of humor 🙂
Sometimes it’s worth taking a furniture-tango risk – as long as you understand that Malm is not made for outdoor use. So yes to a lovingly crafted DIY version, but keep expectations low and avoid stress.
And last but not least: There are plenty of great alternatives made from weather-resistant materials when it comes to long-lasting outdoor solutions. But I totally get that Malm often looks very appealing!
