ᐅ How can MALM furniture be protected from water damage?
Created on: 13 Dec 2020 08:47
lisgu
lisgu
13 Dec 2020 08:47
I own several MALM furniture pieces from IKEA, which I really appreciate. However, since these are mostly made from particleboard with a veneer finish, I am concerned about water damage. Particularly in areas like the bedroom or home office, small spills can happen from time to time.
My question is: How can MALM furniture be effectively protected against water damage, both preventively and if damage occurs? Are there specific sealants, protective products, or tips you would recommend?
I would appreciate detailed advice, including any common mistakes to avoid. Thanks in advance!
Liduta
13 Dec 2020 09:12
Hello lisgu,
To protect MALM furniture from water damage, I recommend a multi-layered approach:
1. Location choice: Avoid placing the furniture close to water sources (e.g., windows with condensation, radiators causing humidity).
2. Surface treatment: Even if the furniture is laminated, applying a thin layer of clear furniture wax or a specialized plastic sealant (e.g., water-based polyurethane finish) can be helpful.
3. Protective mats: Use water-resistant mats under vases, plants, or bowls where liquids might spill.
4. Quick action: If water gets on the surface, wipe it off as soon as possible to prevent moisture buildup beneath the laminate.
5. Protect the floor: If water seeps under the furniture (for example, during floor cleaning), the furniture may swell. Therefore, using raised furniture feet or pads can help.
Common mistakes include cleaning with excessive water or using aggressive cleaning agents that can damage the laminate.
Summary: Prevention + quick response + protective layers as a supplement. If you like, I can provide more details on applying specific products.
Devin
13 Dec 2020 09:28
I would simply stick small rubber feet under the furniture to protect the underside from moisture. Then wipe it well if any water is spilled beside it.
Jatau
13 Dec 2020 09:35
MALM furniture is sensitive to standing moisture. Avoid placing wet items directly on the surface and use coasters.
liste
13 Dec 2020 09:53
I would like to point out that MALM furniture is not made of solid wood but consists partly of medium-density fiberboard (MDF) with a foil coating. Therefore, the protective effect of the foil is crucial.
However, how resistant this foil really is to water depends greatly on the material and the manufacturing process. Can anyone actually confirm that applying a liquid sealant to the foil makes sense? To my knowledge, this often causes the material at the edges to degrade. More precise evidence or product names would be helpful here.
refinar
13 Dec 2020 10:07
I can understand your skepticism. Many sealants work on fabrics or wood, but Ikea films are plastic films that often react sensitively to solvents.
Therefore, I recommend special furniture film sprays or water-repellent protective coatings that are specifically designed for film materials.
Practical tip: Simply test on an inconspicuous spot before treating the entire surface. This way, you avoid damaging the surface.
