ᐅ How can MALM furniture be protected from water damage?
Created on: 13 Dec 2020 08:47
lisgu
I own several MALM furniture pieces from IKEA, which I really appreciate. However, since these are mostly made from particleboard with a veneer finish, I am concerned about water damage. Particularly in areas like the bedroom or home office, small spills can happen from time to time.
My question is: How can MALM furniture be effectively protected against water damage, both preventively and if damage occurs? Are there specific sealants, protective products, or tips you would recommend?
I would appreciate detailed advice, including any common mistakes to avoid. Thanks in advance!
O
onMarcos
13 Dec 2020 10:35
Bundled as a brief guide:
1. Regular maintenance with a damp cloth – not wet.
2. Avoid strong scrubbing or using harsh cleaners.
3. Prevent water from pooling in any areas (e.g., flower pots placed directly on the surface).
4. If water exposure is unavoidable, act quickly and use absorbent materials.
5. Optional: Use a furniture protective coating based on polyurethane, but only after prior testing.
6. Raise furniture feet or place rubber pads underneath.
The most important point is: do not allow moisture to remain on the surface for extended periods.
Following this strategy significantly reduces the risk of water damage.
lisgu
13 Dec 2020 11:04
Thank you very much for the detailed advice so far. I especially want to know more precisely how to respond in case of minor water damage, if water has somehow gotten under the membrane or into the edges.
Is it possible to repair the damage, let it dry, or treat the furniture in any way? Unfortunately, I am not familiar with the exact material properties of the membranes – how does the material react if moisture remains for an extended period?
Thank you, I look forward to your answers!
Liduta
13 Dec 2020 11:23
lisgu schrieb:
How to best respond, repair, and dry minor water damage?
If water gets under the membrane or penetrates through edges, follow these steps:
- Remove furniture immediately from the moisture source.
- Gently blot the affected areas dry with a soft cloth.
- If possible, disassemble the furniture to air-dry the individual parts (especially backs and bottoms).
- Using a fan or a low heating setting in the room can help improve drying.
- Once water penetrates particleboard, it can swell and soften. In most cases, replacement is necessary.
Repairs are usually difficult because swollen particleboard does not shrink back. Small swollen spots are hard to conceal.
Prevention is therefore very important.
Jatau
13 Dec 2020 11:45
Liduta schrieb:
Once water damage penetrates the particle board, it can swell and soften.
Exactly. Once the particle board absorbs moisture, the damage is often irreversible. Prevention is therefore the only effective measure.
liste
13 Dec 2020 12:10
I would still like to suggest considering whether improved sealing at particularly vulnerable areas (such as edges) might be beneficial.
Currently, the edges of Malm are quite thin and usually only have a foil layer without any additional coating. Would an extra clear protective varnish help to reinforce those critical access points?
Or do you have any experience with how such a coating performs specifically on non-flat edges?
refinar
13 Dec 2020 12:32
liste schrieb:
Is painting the edges to protect against moisture a good idea?
That’s a valid approach but it has its challenges. Edges are often more textured or rough, so paint can be applied unevenly and may later peel off.
If you try it, you should apply several thin layers and allow each to dry thoroughly.
Alternatively, some DIYers use water-repellent edge trims that can be glued on—this prevents direct contact of moisture with the edges.
I always recommend doing a detailed material analysis of the panel. Most often, these are melamine-coated particle boards, where a mechanical covering might be more effective than paint.
