Hello everyone, I have noticed cracks in the wood of one of my Malm dressers, probably due to aging or slight material tension. My question is: How can I properly repair these cracks so that they become as invisible as possible while maintaining stability? Which materials and tools should I use, and what is the best step-by-step approach? I want to avoid the repair negatively affecting the appearance of the furniture or damaging the surface. Thanks for your advice!
Hello! Malm furniture is usually made of particleboard with a veneered surface. Cracks often occur when the boards absorb moisture or dry out. Therefore, it is important to first clean the crack thoroughly and allow it to dry. For repairs, wood filler or a mixture of wood glue and fine wood dust can be pressed well into the crack. Afterwards, sand it down so the surface is smooth and even. It is important to then touch up the surface with suitable varnish or a furniture marker matching the color. This way, the repair will be hardly visible and remain durable.
I would like to provide a brief guide on how to properly repair cracks in Malm furniture:
1. Inspect and clean the crack: Remove dust and dirt using a fine brush.
2. Slightly dampen the crack and then let it dry to prevent later expansion.
3. Prepare a mixture of wood glue and fine sanding dust matching the wood color.
4. Carefully press this paste into the crack with a small spatula.
5. Immediately remove any excess and allow to dry for at least 24 hours.
6. Afterwards, sand smooth with very fine sandpaper (grit 240 or higher).
7. Finally, touch up the surface with an appropriate furniture marker or paint.
Avoiding mistakes such as applying too much moisture to the crack or using coarse filler prevents unsightly results.
Nabla64 schrieb:
I would like to give a brief guide on how to properly repair cracks in Malm furniture Thank you very much for the detailed instructions. What do you mean by "slightly dampen and then let dry"? Is that really necessary before filling? Some say it could cause further damage to the wood.
dufako schrieb:
What do you mean by 'slightly dampen and then let it dry,' is that really necessary before filling? Yes, but only very sparingly and in specific spots – for example, lightly moisten the crack with a damp cloth or brush. This helps the wood glue to penetrate and adhere better. It is important that the surface does not become wet and that it is completely dry before applying the filler. If this seems too risky, you can skip this step and just clean the area thoroughly.
