ᐅ How do I repair Malm furniture with damaged wood?
Created on: 18 Aug 2024 09:12
ken47
Hello everyone, I have a few IKEA Malm furniture pieces with damaged wood, mainly scratches, dents, and some chipped edges. Since I don’t want to simply throw these pieces away, I’m looking for tips and methods to properly and permanently repair such wood damage. I have considered wood filler and putty but am unsure about the best way to apply them, especially on the coated surfaces of the Malm series. What tools, materials, and steps are most suitable here, and how can I avoid damage from moisture or improper sanding? Additionally, I’m interested in how to maintain the original appearance as closely as possible. I look forward to your advice!
Kinbu
18 Aug 2024 13:28
Hello ken47, I would like to add that when repairing damaged wood on Malm furniture, preparation is crucial. The surface should be not only clean but also completely dry to ensure good adhesion of glue and filler.
If the veneer is torn but mostly still intact, it is recommended to lightly roughen the area to improve the adhesion of touch-up paint or varnish. It is important to remove any excess material immediately after application before it hardens.
Dilen schrieb:
Sanding should be done very carefully to avoid further damaging the veneer.
That is very good advice. A common mistake is using coarse sandpaper on the edges, which causes even more damage to the veneer.
Many users also underestimate the importance of temperature and humidity during the process. Repairing in high humidity can reduce adhesion and lead to the filler peeling off later. Therefore, it is best to work at room temperature and in dry air 🙂
Elijah42
18 Aug 2024 13:55
Edge banding for Malm is usually available online with sample ordering to find the right color.
A sharp knife and an iron are sufficient for application.
After sticking it on, smooth the edges with fine sandpaper.
ken47
18 Aug 2024 14:30
Joshbe schrieb:
For hard-to-reach areas, a combination of a narrow utility knife and small clamps for securing is helpful.
Good tip, thanks! I’ll get myself some of those clamps.
My last question before starting: Can I also use wood glue on damaged spots to attach loose parts, or is that problematic because of the film? When in doubt, I’d rather play it safe and avoid risking the film coming loose or wrinkling due to the glue.
Dilen
18 Aug 2024 15:12
ken47 schrieb:
Can I use wood glue to secure loose parts in the damaged areas?
In principle, yes, but with caution. If the membrane is extensively detached from the substrate, wood glue can help to reattach it. Apply the glue thinly and sparingly, and make sure to firmly secure the area to avoid bubbles.
Important: Use waterproof D3 or D4 wood glue that swells minimally. Water-based glues can lift the membrane.
If the membrane is lifting at the break edge, it might be better to temporarily fix that edge with suitable tape and then treat the break with a thin layer of a repair adhesive tested for compatibility with membranes.
If you prefer to cover the damaged parts in one step by filling, then any loose parts must definitely be secured beforehand.
How large are the loose parts – are they small splinters or larger panel sections? And where exactly on the Malm is this?
ken47
19 Aug 2024 08:05
Dilen schrieb:
How large are the loose pieces – are they small chips or larger panel sections?
Good morning, thanks again for your detailed response. The loose pieces are rather small, about 1 to 2 cm (0.4 to 0.8 inches) long chips along the edges of the nightstand. Fortunately, larger panel sections are not affected.
So I plan to carefully secure them first using D3 glue, then gently sand and fill those areas. I will update on how it goes!
KAULIS
20 Aug 2024 09:44
I would like to add a brief note to the discussion: When filling, make sure the wood filler is suitable for melamine surfaces or plastics, as Malm furniture is usually coated with melamine resin.
An important detail when smoothing: After drying, it is recommended to use very fine sandpaper (at least grit 240). Then, you can seal the area well with matt furniture wax or special repair lacquers to achieve a matte finish.
Repair kits containing color pastes have also proven effective – although the result may not be convincing for larger damages. However, for smaller scratches, they are definitely worthwhile.
