ᐅ How do I properly replace the drawer handles on a Malm dresser?
Created on: 12 Jul 2020 08:37
Z
zhielHello everyone,
I want to replace the drawer handles on my Ikea Malm dresser and have a few questions: What is the best way to properly change the handles? Are there any specific details to keep in mind for this model, for example regarding the screws or the mounting method? I want to avoid causing damage to the drawer front by using the wrong screws or over-tightening them.
Also, I’m curious if it’s advisable to reuse the old screws or if it’s better to use completely new mounting hardware. What type of screws are actually ideal, and is it worth using a special screwdriver or drill bit?
I would appreciate tips on the right tools, preferably including advice on stability and appearance after replacing the handles. Thanks in advance for your help!
zhiel schrieb:
Are there any special considerations with this model, for example regarding the screws or assembly method?In short: yes, and this is often overlooked. The Malm drawers are basically simple in design, but the standard screws are often too short or not very high quality. This causes the handles to become loose or even fall off after a few months – which, honestly, makes you question Ikea’s philosophy.
My advice: definitely use stainless steel screws instead of the standard zinc-coated ones. They last longer and don’t corrode as quickly, especially if you think the furniture will only be indoors and safe from moisture.
And very important: don’t overtighten the handles! This is a classic mistake among DIY assemblers. Just tighten them firmly by hand; if you apply too much force, you can damage the wood or the finish.
I can only agree with rebufar and would like to add: Honestly, I was also afraid of damaging something when changing the handles. In my opinion, it helps to treat the screws with a drop of WD-40 or a similar lubricant before unscrewing them, especially if they are stuck. This makes removal much easier and reduces the risk of cracking the wood.
Also, when installing the new handles, I recommend initially tightening the screws by hand and then finishing with a screwdriver – it’s really about finding the right balance between tight enough and too tight. Personally, a small ratchet with a torque limiter worked really well for me.
Have you had any experience with different handle materials? I’m considering replacing my wooden handles with matte brushed metal ones, as they seem more durable.
Remove handles: loosen screws with a Phillips screwdriver.
Check old screws, it’s better to use new ones.
Do not overtighten when attaching, as this can damage the front.
If necessary, adjust the screw length; Malm has thin fronts.
Metal handles are more durable, wood can splinter.
Malm usually has standardized drill holes for handles, so most Ikea handles fit directly without the need for redrilling.
When attaching screws, apply gentle pressure and tighten by hand or with a screwdriver.
For additional stability, use washers depending on the type of handle.
rebufar schrieb:
Definitely use stainless steel screws instead of the standard galvanized ones.I wouldn’t recommend that as a general rule. Stainless steel does offer advantages in terms of corrosion resistance, yes, but it is often more brittle and can break more easily if overtightened.
What’s more important is choosing the correct screw size and a suitable screw head type. For furniture, zinc plating is usually sufficient as long as you are careful not to apply too much force.
And why use the term "professionally done" (or "correctly executed") at all? Isn’t this word often used for something that should be a given? To me, professionally done also means that the installation can be completed cleanly without any lasting damage – and in my experience, this works best with original materials and careful handling.
