ᐅ How do you repair MALM drawers?
Created on: 25 Jul 2024 08:12
Colbytan
Colbytan
25 Jul 2024 08:12
I have been experiencing issues with my IKEA Malm drawers for some time now. Specifically, some drawers no longer slide in and out smoothly; they sometimes stick or even jam. Additionally, on two drawers, the side runners are slightly bent or have come loose from their mounts. My question to the community is: What is the best way to repair Malm drawers when the runners no longer operate smoothly, the guides are sticking, and certain parts may need to be replaced? Is special tooling required, and are original replacement parts from IKEA recommended, or are there universal compatible alternatives available?
For efficient answers, it would be great if you could cover common causes, a step-by-step repair guide, or common pitfalls to avoid during the repair. Thanks!
Ramon4
25 Jul 2024 08:47
Hello Colbytan,
your question is very well formulated and shows that you already have a good understanding of the issue. MALM drawers are known for their slides wearing out or shifting over time.
First, you should check the screws on the slides – they often loosen and cause the drawer to stick or tilt. Then I recommend removing the drawer completely and inspecting all the slides for visible damage or dirt.
Original replacement parts from IKEA are definitely recommended if available, as they fit exactly. Of course, there are also universal drawer slides, but these usually do not fit perfectly, which can lead to recurring problems later.
In terms of tools, you mainly need a Phillips screwdriver and possibly pliers if you need to fix minor deformations in the metal guides.
Important: when reinserting the drawer, make sure it fully clicks into the slides; otherwise, it can be very frustrating later.
If you want, I can also provide you with a detailed step-by-step guide.
Colbytan
25 Jul 2024 09:15
Thanks in advance, Ramon4! A step-by-step guide would be great, especially tips on how to properly align the drawer slides. With two drawers, I’ve already noticed that the sides are slightly “misaligned” in some places, which probably causes them to stick. Is there a way to fix this without having to completely rebuild the drawer?
LOGEMIN
25 Jul 2024 10:02
Hello Colbytan,
I’m happy to jump in with a brief guide to make things easier for you.
1. Remove the drawer: Carefully pull the drawer completely out. In MALM models, there are usually small plastic levers or metal clips on the runners that need to be pressed or lifted briefly.
2. Check the runners: Inspect the runners for any bends or dirt (dust, hair, small debris).
3. Adjustment: If the runners are bent, you can gently bend the guide rail back into its original position using pliers or your hands. Be careful not to apply too much pressure, as the metal can be easily damaged.
4. Tighten screws: Loose screws are often the cause of misalignment. Tighten the screws on the runners and on the cabinet body.
5. Position check: If the guide on the drawer itself is loose, check the clips or holders and replace them with IKEA spare parts if necessary.
6. Reassembly and test: Reinsert the drawer. When doing so, pay attention to smooth and even movement. Sometimes you need to slightly lift or tilt the drawer for it to run smoothly.
Additional tips: Use a bit of silicone spray as a lubricant on metal runners, but avoid oil, as it attracts dust.
Original spare parts are also available online from IKEA. Sometimes the runners are sold as a complete set.
I hope these steps help you!
gasidney
25 Jul 2024 10:28
Pull out the drawer, clean the drawer slides, tighten the screws, straighten the slides, put the drawer back in, test it. Silicone spray often helps. Done.
blapau
25 Jul 2024 11:03
A small additional note:
You should also check the side guide rollers. MALM often uses plastic rollers that can wear out or break over time. If these are damaged, you can replace them without needing to exchange the entire drawer.
Also, make sure the drawer front is not warped, as this can also affect the sliding function. If so, it is advisable to check the front screws and carefully adjust them if necessary.
