ᐅ IKEA MALM Bed Creaking Despite Maintenance – What to Do Now?
Created on: 16 May 2015 07:43
gauno
Hello everyone, I have the following problem: My IKEA Malm bed still squeaks despite regular maintenance and tightening of the screws. I have checked the screws multiple times, lubricated all the joints, but the creaking and squeaking persist. It’s quite annoying, especially at night when turning or getting up. Does anyone know this problem and have suggestions on what else can be done? Maybe the design or the material is just prone to this? I would appreciate any tips on what I can try without having to take the bed apart or buy a new one.
Parmin
16 May 2015 12:14
gauno schrieb:
Graphite powder is a good idea, but hard to get where I am. Are there alternatives?
Alternatively, you can use dry lubricants, like those available at bike shops, or special dry sprays from the automotive sector. These do not soak in and help prevent rattling and squeaking.
Also, you should check whether the screws are really tight and if the washers between the frame and the slatted bed base are not porous or worn out. If the wood at the support points is worn, the squeaking may persist.
gauno
16 May 2015 13:57
Parmin schrieb:
Whether the materials between the frame and the slatted base are not porous or worn out
I’ve taken a closer look at the supports now. It does seem like the small plastic dampers are somewhat compressed and no longer fit tightly.
Could this be the cause? If so, would it make sense to replace them? Are there any recommendations on which parts work best? If this is a weak point, it would be helpful to know what replacements are suitable.
LOPAU
16 May 2015 14:30
The plastic dampers are often the cause of persistent squeaking in Malm beds. Their original purpose is to act as a sliding element and protect the wood. If they are worn out or compressed, direct wood-to-wood contact causes the noise.
My tip: Replace the dampers with new ones, preferably the original parts from IKEA. If these are not available, strips of hard rubber or soft leather, cut to size, can help. These will cushion and protect the contact surface.
leebi7
16 May 2015 15:12
To address the issue from a technical perspective: The squeaking usually results from friction between parts that move or slightly shift against each other. In MALM beds, this often occurs where the slatted frame rests. Small movements cause shear and pressure forces on the plastic dampers.
These dampers are typically made of polyurethane or similar materials, which harden or become compressed over time. As the dampers lose their elasticity, the friction resistance increases, leading to the squeaking.
Recommended steps:
1. Remove the old dampers.
2. Replace them with new ones or with firm rubber or leather pads.
3. Check that the slatted frame fits snugly but not too tightly, to avoid excessive movement.
Additionally, lightly sanding the contact points can help smooth the surface. Important note: Do not use overly soft or sticky substances, as they tend to worsen the problem.
gauno
16 May 2015 16:05
Thanks, that sounds like a good plan. I will order the dampers from IKEA tomorrow or check them out in store.
leebi7 schrieb:
Check if the slatted frame is tight but not too tight
So far, I have always secured the slatted frame very firmly to prevent any wobbling. Could this also increase the squeaking if the frame is under too much pressure?
Parmin
16 May 2015 16:45
gauno schrieb:
I have always fastened the slatted frame very tightly so that nothing wobbles.
That's exactly the point. If the frame is tightened too much, it creates a constant tension that amplifies small movements and friction. A "floating" installation with a little play can often eliminate the squeaking.
Maybe start by replacing the dampers and then avoid tightening them too much. A balanced approach is needed.
