Hello everyone, I have noticed that some edges of the frame on my Malm bed have developed cracks and chipping. These look unattractive, and I am concerned that the damage might worsen over time.
I am interested in learning how to best repair these cracked edges myself, without having to disassemble the bed or order entirely new parts.
Are there specific adhesives, fillers, or treatments that work especially well on the surface of MALM beds made from particleboard or laminate?
I would appreciate any advice, material recommendations, or practical experiences you can share!
Hello Ilanfo, I understand well that chipped edges on MALM beds can be very annoying. These beds are made from particleboard with a laminate-like surface, which means that simple wood filler products often are not the best solution.
My advice would be to first carefully clean the damaged surface and remove any loose parts. Then you can use wood or even plastic filler that is specially designed for laminated surfaces. After drying, gently sand the surface to achieve a smooth finish. It is important not to round the edges too much so they don’t look noticeably different.
After that, a solid-color laminate adhesive or color-matched spray paint can help restore the appearance. If the color does not match exactly, you can touch it up with a fine brush.
Does this help you? If you like, I can also provide a step-by-step guide.
I often wonder how many of us simply go for a new bed instead of taking the time to fix small damages.
I believe that with the right filler and some paint, you can achieve great results and even feel better about repairing something yourself. That’s what sets it apart from just buying new furniture.
Ilanfo schrieb:
Are there special adhesives, fillers, or finishing methods that work particularly well on the surface of MALM beds made of particleboard or laminate?
