ᐅ How do I repair Malm furniture after water damage?
Created on: 31 Dec 2021 08:13
Eleni55
I have a few Malm furniture pieces from IKEA that were unfortunately damaged by water, especially at the edges and the feet. The coating is peeling off in some areas, and the wood underneath has swollen or expanded. I don’t want to completely dispose of the furniture but instead try to repair it properly.
My question is: What is the best way to repair Malm furniture after water damage? Which materials and tools do I need to treat the swollen areas, restore the coating’s appearance, and maintain stability?
Are there any special techniques you can recommend to reduce or eliminate swelling in the particleboard core? And how should I handle the damaged edges so the piece looks as close to new as possible?
I’m looking forward to practical tips and experiences!
tolokau
1 Jan 2022 14:30
Eleni55 schrieb:
Epoxy resin sounds interesting, but is it difficult for beginners to work with?
Not necessarily difficult, but you need precise measuring and should avoid inhaling the fumes. Gloves and a respirator are recommended. For small repairs, simple putty knives and sandpaper are sufficient.
Eleni55 schrieb:
Are there any suitable wood fillers that are water-resistant?
Yes, there are waterproof acrylic wood fillers. They are less durable than epoxy, but when combined with a final sealant, they are quite effective.
Eleni55 schrieb:
What is the best way to replace or clean melamine foil on edges?
You can clean the foil with mild dish soap and a microfiber cloth. For edges where the foil has peeled off, self-adhesive PVC edge strips are a good option; these are available in various colors and thicknesses at hardware stores and can be easily applied with a utility knife and glue.
Parbo
2 Jan 2022 09:21
Regarding epoxy resin again: For beginners, it is especially important to mix the resin and hardener exactly as specified (usually 1:1 or as indicated on the packaging).
Too much hardener or resin will affect the curing process.
Application should be done at room temperature (20-25°C / 68-77°F) using a plastic spatula, wooden stick, or similar tool. Always wear gloves.
A small tip: Minor air bubbles can be carefully removed with a heat gun—but do not overheat!
When removing loose film, always cut carefully along the damaged areas with a utility knife or scalpel to ensure clean edges. Afterwards, make sure to lightly sand the edges so that wood filler and paint adhere better.
