Good morning everyone, I have been working on an IKEA Malm piece of furniture for some time and am experiencing the problem that some fasteners, especially screws and dowels, have become loose. My question is: What is the best way to repair loose fasteners on Malm furniture to ensure lasting stability again? Which tools and materials are recommended, and are there ready-made replacement parts or tricks to fix damaged screw holes, for example? I look forward to your proven methods and tips.
Regarding the topic of "loose fasteners in MALM," I recommend first completely removing the affected screws and dowels to inspect the condition of the drilled holes. The issue is often caused by worn out or softened holes that prevent proper tightening. For repairs, common wood filler or wood glue combined with wooden dowels can be used as reinforcement elements. In cases of more significant damage, wooden strips or suitable screw anchors can be employed to create new fastening points. In terms of tools, a good screwdriver or cordless drill with torque control is sufficient.
I know this problem from personal experience; it can be really frustrating when furniture starts to wobble after a short time. I want to encourage the original poster: with a bit of patience and the right tools, you can usually tighten these joints again. It also helps to be careful not to overtighten the screws during assembly. If the holes become too large, I have had good results using toothpicks or wooden sticks, which you can insert with some wood glue until they are secure. Filling the holes this way is a simple and cost-effective solution.
As a supplement to the previous tips, here is a simple step-by-step guide for repairing loose fasteners on MALM:
1. Remove screws/dowels and clean the drill hole.
2. If the hole is damaged or frayed, fill it with wood glue and a wooden dowel (matching the hole diameter). Trim the dowel slightly before inserting.
3. Alternatively, you can use wooden toothpicks or small wood pieces with glue, inserting them multiple times until the hole is filled.
4. Allow everything to dry thoroughly (at least 2-3 hours).
5. Then carefully reassemble the furniture using the original screws.
Common mistakes include insufficient drying time or tightening the screws too much, which can damage the wood again. Patience is the key to success here.
nojaus schrieb:
If the holes become too large, I have had good experience using toothpicks or wooden sticks This is a good, practical tip. It is important to ensure that the fillers are not just inserted, but also coated with wood glue. This significantly increases the stability. I also recommend lightly sanding the dowel or wooden piece after it has dried to achieve a flush surface.
A common weakness with MALM furniture is that the MDF panels and connecting screws are prone to issues when repeatedly tightened. Therefore, for recurring problems, I recommend using so-called "Helicoil" threaded inserts or metal sleeves. These require some experience and tools but provide a very durable solution since the threads in the wood no longer strip out. For DIY enthusiasts without specialized tools, the tips involving wood glue and wooden dowels are a better choice.
