Good morning everyone, I have been working on an IKEA Malm piece of furniture for some time and am experiencing the problem that some fasteners, especially screws and dowels, have become loose. My question is: What is the best way to repair loose fasteners on Malm furniture to ensure lasting stability again? Which tools and materials are recommended, and are there ready-made replacement parts or tricks to fix damaged screw holes, for example? I look forward to your proven methods and tips.
In addition to the methods already mentioned, it is important to follow the correct tightening sequence: when working with particleboard, screws should always be tightened gradually in a crisscross pattern to ensure even load distribution on the furniture. Retightening after 1-2 days can also be helpful, as wood expands and materials settle. I would also recommend avoiding oversized or excessively long screws, as these can weaken the joint or cause the wood to split.
Paxton38 schrieb:
It is important that the filler pieces are glued with wood adhesive.Correct. Alternatively, there are special furniture wood repair kits that contain epoxy resin-based fillers. These are especially durable and are suitable for severely damaged holes. Although they require longer curing times (up to 24 hours), they provide a very strong base for screwing in new fasteners afterward.
I would also recommend focusing on prevention. Connection elements in MALM furniture often loosen because the piece is overloaded or moved improperly. Therefore, it is important to check whether the weight limits are respected and that no unacceptable shear forces are acting on the joints. Additionally, rubber adhesive strips or small felt pads at the connection points can help minimize vibrations.
Jensson schrieb:
Patience is key to success here.Thanks to everyone for the detailed and practical advice! The tip about drying time and the use of wooden dowels is especially helpful. For me, it’s now clear that carefully preparing the drill holes and reassembling slowly are crucial. One more question: Are there often issues with certain screw types in MALM components, or are the original parts generally sturdy enough? Is it better to purchase original parts again, or should one avoid generic replacements?
