ᐅ Why do Malm bedside tables tend to wobble?
Created on: 20 Nov 2021 08:23
brigitte
I have a somewhat specific question: Why do Ikea Malm nightstands tend to become wobbly quite quickly? I own two of these tables and notice that despite seemingly correct assembly and normal use, they keep loosening and wobbling. I’m interested in whether this is due to the furniture design or materials, or if it’s more related to the way they are assembled. I would appreciate it if anyone with solid knowledge or experience could share their insights!
Thanks in advance.
CARLA
20 Nov 2021 11:05
In summary, the main issue with the Malm nightstand lies in the materials used and the construction method.
The nightstand is made of medium-density fiberboard (MDF) with a foil coating, which is common for affordable furniture but does not provide the long-term durability of solid wood under mechanical stress and frequent use.
The fasteners are typically conventional dowels and simple metal fittings, which tend to loosen more quickly, especially when the wood experiences minor deformations.
Regular tightening of the screws after a few weeks of use is therefore essential, but this is often not clearly communicated with ready-to-assemble furniture.
For improved stability, it is recommended to use wood glue on the dowels during assembly and to reinforce the corners with brackets or stronger fittings.
brigitte
20 Nov 2021 11:45
rondi schrieb:
The wobbling usually comes from screws or anchors that are not secured properly.
Thanks, that makes sense to me, but I have checked and tightened the screws several times.
koneo schrieb:
The material is quite soft and sensitive at the joints.
That might be the key point, especially since I use the tables daily and always place my water bottle there.
Giagau schrieb:
Retrofitting with metal brackets or stronger screws can help.
Can you provide specific examples of the type of brackets or screws that have proven effective? I’m not very skilled in DIY, but I’d like to do something.
And what about pads for the feet – how should they be chosen to improve both floor protection and stability?
koneo
20 Nov 2021 12:08
Hello brigitte,
For metal brackets, I recommend simple L-shaped steel brackets like those found in hardware stores for shelving. It’s important that they are not too large and fit well with the edges of the bedside table.
The screws should preferably be self-tapping and match the thickness of the material, about 3 to 4 cm (1¼ to 1½ inches) long.
To protect the floor and improve stability at the same time, felt pads that are stuck to the bottom of the table legs are helpful. They compensate for small unevenness and reduce wobbling.
If it’s very unstable, you can also use small plastic shims, which are available at hardware stores.
Be confident, it’s not that complicated! 🙂
Giagau
20 Nov 2021 12:36
Regarding reinforcement: When using metal brackets, make sure the screws are driven into the solid wood frame or the strongest areas to ensure durability.
Sometimes it can be helpful to reinforce the furniture with wood glue at the joints, especially if you are willing to invest a bit more.
Moisture and temperature fluctuations can cause MDF to swell, which may lead to loose joints.
Make sure the bedside table is not placed directly next to radiators or in areas with high humidity.
V
Vinlen
20 Nov 2021 13:01
brigitte schrieb:
And what about pads under the feet?
Regarding pads: felt glides are very good if you want to move the table frequently; they help to dampen movement. For maximum stability on uneven floors, small wooden or plastic wedges are suitable, as they can be cut to size to secure the table.
Sometimes it is also worth checking the floor directly under the table – if it shifts due to changing conditions, the bedside table will continue to move.
CARLA
20 Nov 2021 14:17
I would like to add that constructive compromises are common for mass-produced furniture, such as the Malm model.
Thanks to low production costs and the use of MDF panels, the piece is visually appealing and affordable but mechanically limited.
Therefore, this type of furniture should not be equated with solid wood furniture – a certain tolerance for loose joints should be expected, and regular inspections are recommended.
Long-lasting stability can only be achieved with additional reinforcement or a targeted modification.
