ᐅ Why do Malm bedside tables tend to wobble?
Created on: 20 Nov 2021 08:23
brigitte
I have a somewhat specific question: Why do Ikea Malm nightstands tend to become wobbly quite quickly? I own two of these tables and notice that despite seemingly correct assembly and normal use, they keep loosening and wobbling. I’m interested in whether this is due to the furniture design or materials, or if it’s more related to the way they are assembled. I would appreciate it if anyone with solid knowledge or experience could share their insights!
Thanks in advance.
Trate47
20 Nov 2021 15:02
Hey everyone :-) I think the Malm nightstand is really a classic, but of course, once you know its limitations, it can still bring a lot of joy.
Honestly, a shaky piece like a Malm nightstand can easily be stabilized with a few simple tricks. Just add metal brackets plus stronger screws and put small felt pads under the feet, and you’ll have a cozy, stable companion 🙂
Also, consider whether the floor itself might add some variety – even a wobbly stage can turn into a show, right? 😉
KARJU
21 Nov 2021 09:33
Here is a summary of the key points:
- Malm nightstands are made of MDF, which can weaken over time under load.
- Screws and wall plugs are standard but are not designed for permanent heavy use.
- The quality of assembly is very important: screws need to be tightened regularly.
- The surface the furniture stands on significantly affects stability.
- There are simple but effective solutions for retrofitting metal brackets, felt pads, and shims.
Recommendation: If there is significant wobbling, regularly check the screws and add reinforcements if necessary.
brigitte
21 Nov 2021 10:01
Thank you all for the detailed answers!
Next week, I will gather the tools and recommended materials and retrofit the nightstand accordingly. I found the advice about the metal brackets and the explanation of MDF particularly helpful.
Thanks also for the tip about the moisture—the nightstand is actually placed close to the radiator, which I will change.
Once I’m finished, I will gladly provide feedback on whether the stability has improved.
