ᐅ Are there any tools for sanding Malm wood?
Created on: 15 Jul 2021 09:12
Haumirza
Haumirza
15 Jul 2021 09:12
Good morning everyone, I have a somewhat specialized question and hope that experienced members here can help. I am interested in the topic of sanding Malm wood. Malm is known to be a very hard and tough-fibred wood, so I am wondering if there are specific tools or abrasives that work especially well to achieve a smooth surface without damaging the material. Which machines, abrasives, or techniques are recommended? Are there any particular considerations to keep in mind when working with Malm wood? I look forward to concrete tips and practical experiences! Thank you in advance.
gadalu
15 Jul 2021 09:45
Very good question. Malm wood is indeed challenging to work with due to its hardness and density. Generally, I recommend using abrasives with a higher grit and high wear resistance for sanding Malm wood, preferably sanding belts or sandpapers made with aluminum oxide or zirconia alumina. For machines, a belt sander or random orbital sander is suitable. It is important to keep the speed low to avoid overheating the wood.
Additionally, make sure the abrasives are not too coarse to prevent the surface from remaining too rough after sanding. A gradual approach from coarse to fine grit is advisable.
nonpra
15 Jul 2021 10:03
I would suggest starting with a 120-grit and then moving on to 240-grit and finer. Belt sanders with zirconia alumina abrasives work well.
O
ODINFLO
15 Jul 2021 10:37
I wonder if the heat generated during sanding also affects Malm wood. For example, if sanding is done at too high a speed, is there a risk that the wood might discolor or that the sanding dust might settle and clog the pores?
Does anyone have data or experience indicating the optimal sanding speeds or feed rates for Malm wood?
gadalu
15 Jul 2021 11:02
ODINFLO schrieb:
I wonder if the heat generated during sanding also plays a role with Malm wood.
That is correct. Especially with resin-rich and dense woods like Malm, it is important to keep the temperature under control. High speeds can cause thermal damage. Practical experience shows that sanding speeds in the mid-range of about 5,000 to 6,500 rpm (revolutions per minute) for random orbital sanders are beneficial, along with gentle pressure.
Additionally, intermediate sanding with slightly coarser grits and sufficient dust extraction is important.
elgla
15 Jul 2021 12:28
I know the problem—Malm wood can be really tricky! In my first project, I was frustrated because I used the wrong sandpaper, and the surface ended up very uneven. My advice: take it slow and change the abrasive grit more often. It also helps to use dry wood and sand in multiple stages.
It’s definitely a challenge, but with patience, it works out. If you’re having difficulties too, don’t get discouraged!
