ᐅ How do I repair damage to MALM furniture?
Created on: 25 Aug 2023 14:03
Habib49
I have several Malm furniture pieces from IKEA that have developed small to medium-sized damages from everyday use over the past few months. Specifically, there are scratches on the surface finish, some chipped edges, and a few loose screws or joints. Since I don’t want to simply replace the furniture, I would like to know the best and most durable way to repair these issues.
Which materials and tools are best suited for this? Are there specific repair kits recommended for Malm due to its material (particleboard with a laminated surface)? How can I cleanly repair chipped edges without the result looking messy?
I’m really looking forward to your experiences and tips—preferably with practical step-by-step guides or useful tricks! Thanks in advance.
Habib49
26 Aug 2023 09:12
Thank you for the quick and helpful responses so far!
A follow-up question: Is it possible to use standard wood filler for solid wood furniture with Malm, or does it have to be a special type? I’ve read that because of the chipboard and the foil surface, extra care is needed; otherwise, the material might swell or the filler may not adhere properly.
Regarding sealing: Is it better to apply clear varnish after filling, or is furniture wax sufficient? And what about repair kits available for purchase—do they really provide better adhesion than, for example, regular wax fillers or putty from hardware stores?
I would appreciate detailed opinions and maybe even some testing experience!
Joshbe
26 Aug 2023 09:55
Regarding your question, Habib49:
For MALM furniture, you should not use regular wood filler intended for solid wood. MALM is made of medium-density fiberboard (MDF) or particle board with a melamine foil surface. These surfaces are not very absorbent and are sensitive to moisture.
It is recommended to use special repair fillers designed for foil or plastic surfaces, which are waterproof and adhere well without softening the foil. These products are specifically formulated for furniture with coatings.
Regarding sealing: furniture wax alone provides only light protection. For areas repaired with filler, clear coats based on acrylic or polyurethane are advisable, as they create a hard, durable layer that lasts longer.
Investing in repair kits often pays off because they include matched colors along with suitable adhesives and filler materials. Regular wax sticks or fillers from hardware stores often do not have the ideal properties for foil-covered furniture and usually do not hold up as well.
In short: it is best to use product solutions specifically recommended for coated furniture.
Siflo
26 Aug 2023 11:30
In addition to what Joshbe mentioned:
For loose screws in MALM furniture, it is advisable not to simply retighten if the hole is worn out. In such cases, you can apply wood glue into the hole and insert a small wooden dowel or toothpick before screwing the screw back in. This will give the joint more stability.
If the damage is more severe, for example a torn edge of a panel, replacing the damaged parts might be more cost-effective. However, for minor repairs, the method described here is definitely worthwhile.
When repairing scraped edges, it is important to smooth the wood filler as evenly and flush with the surface as possible, since the veneer is not flexible and can otherwise develop unsightly cracks.
nojaus
26 Aug 2023 12:47
I really like how everyone is sharing their tips here. 🙂
I once felt frustrated myself when a MALM wardrobe I owned got some minor edge damage, and I didn’t immediately know how to fix it. I tried repairing it with filler and paint, but at first, I wasn’t happy with the result, and it was honestly a bit annoying.
My advice for anyone feeling unsure: take your time and don’t be afraid to make small mistakes at the beginning—that’s completely normal. You can always improve the result in several stages. More important than perfection is that you still feel comfortable with the piece of furniture after the repair. :-)
If you have success, please feel free to share photos or something similar, so we can all celebrate together! 😉
FLONE41
27 Aug 2023 08:15
Hello everyone, I’d like to share my experience as well. Unfortunately, my MALM bed had significant damage on one corner, and I tried to repair it myself using a repair kit from IKEA. The instructions provided were quite good, and the result pleasantly surprised me.
I think it’s very important to sand the area well and work carefully before applying the filler or paint/kit. Otherwise, nothing will hold permanently.
If you’re unsure whether the damage is only superficial or structural, it’s best to carefully check if the stability is still fully intact or if a completely new panel is needed. Safety comes first!
I wish you all good luck with your repairs.
teyosef
27 Aug 2023 09:48
FLONE41 schrieb:
I’m keeping my fingers crossed that your repairs go well.
Thank you for the kind wishes!
Finally, a tip for color matching during repairs: test small areas in inconspicuous spots or on a piece of paper before applying the material to the furniture.
Many furniture sets provide mixing instructions for paints to achieve the best color match. This is especially true for MALM, which is often white or very light, so patience pays off 🙂
If anyone is interested, I can also gladly share recommendations on specific products or brands that have proven effective.
