ᐅ How do I repair Ikea Hemnes furniture with paint inclusions or blemishes?
Created on: 13 Sep 2020 08:17
JUDASSON
JUDASSON
13 Sep 2020 08:17
I have noticed some unsightly paint inclusions and small damages on my Ikea Hemnes furniture, especially in heavily used areas. Before considering repainting the entire piece or replacing it, I would like to know the best way to specifically repair these paint defects and surface damages.
I have already tried using simple repair markers but was not satisfied because the color tone and texture did not really match.
Does anyone know reliable methods or products that work well for painted or paint-like surfaces like those on Hemnes? What is the best approach to make the repair as invisible as possible and ensure it lasts long-term? Are there differences to consider between small scratches and paint inclusions?
Looking forward to your advice!
Luke44
13 Sep 2020 09:42
It's best to use fine sandpaper (grit 400 or higher) for color stains, lightly sand the area, clean it, and then apply a suitable furniture or touch-up pen. Finish by sealing with clear varnish.
FAZAR
13 Sep 2020 11:55
first, it is important to clearly distinguish the type of damage: paint inclusions usually occur during the painting process, while dents or chips are caused by mechanical impact. For both cases, I recommend a careful approach:
- Cleaning: Remove dust, grease, or wax with a mild solvent (e.g., isopropanol).
- Sanding: Use very fine sandpaper (grit 600-800) only in the direction of the grain to avoid further damaging the surface.
- Color matching: The Hemnes finish is often a type of clear coat or white-pigmented finish. A touch-up pen that is too light or too dark will be very noticeable. Ikea does not offer official touch-up paints, so commercially available spray paints from the scale modeling sector or special furniture repair pens are often more suitable.
- Application: Apply several thin layers, allowing each to dry thoroughly.
- Sealing: Finally, seal with a thin clear coat from a spray can—avoid brushes to prevent visible strokes.
A common mistake is applying too thick a layer or using coarse sandpaper. A question for you: Are your dents typical scratches, or are they paint defects where the underlying material is peeling? This significantly affects the repair technique.
PERON
13 Sep 2020 13:07
Oh yes, I know this topic all too well! Hemnes is really beautiful, but small imperfections can quickly become noticeable. 😉
I’ve had good experiences with repair kits for wood and finish; they usually include small amounts of filler, touch-up markers, and clear varnish. It’s important not to enlarge the damage before starting the repair.
Also, when repairing, remember to lightly polish the area with an ultra-fine sanding pad (e.g., 1200 grit) after applying the varnish – this gives the final touch so it doesn’t look like a DIY fix.
Be patient; sometimes it takes several coats and some drying time. And hey, a little bit of patina actually adds character, in my opinion. 😉
rubybi
14 Sep 2020 07:50
Hello JUDASSON,
I’m picking up the topic and providing you with a structured step-by-step guide for your Hemnes repair:
1. Preparation
- Clean the damaged area thoroughly with a lint-free cloth and isopropanol to remove all grease.
- Check the depth of the chip: Is the damage only superficial, or does it go down to the substrate?
2. Sanding
- Use very fine sandpaper (at least grit 600) or sanding sponges, sanding carefully in the direction of the grain.
- Avoid exposing bare wood, as that will make color matching more difficult later.
3. Color Matching
- Use touch-up markers specifically designed for white painted furniture surfaces.
- Apply the color in thin layers and allow each layer to dry well.
4. Clear Coat
- After drying, seal the area with a matte clear spray lacquer or furniture clear coat.
5. Finishing
- Optionally, gently sand with very fine abrasive pads and polish.
Common mistakes include applying paint layers that are too thick, insufficient drying time, and using the wrong color.
If you have deeper scratches or missing paint layers, I recommend testing on a small, inconspicuous area first.
If you like, you can also provide the exact Ikea color number—I can help you narrow down the matching shade.
SUBEN60
14 Sep 2020 10:21
For a long-lasting repair, you should use materials that closely match the original paint. Ikea Hemnes furniture usually has a white painted MDF carcass with a matte or satin-matte finish.
- Use repair kits from specialist furniture suppliers that are designed for MDF and white lacquer.
- For paint inclusions: carefully remove them with fine sandpaper, clean the area, then apply a thin coat of paint matched to the color.
- Make sure to seal the surface after it dries with an appropriate clear coat to protect against wear.
- Avoid using harsh cleaners on the repaired area.
Professional repainting is usually only necessary if the damage is extensive or the paint is peeling significantly.
