ᐅ How do I repair damaged soft-close drawer systems in IKEA Metod kitchens?
Created on: 26 Oct 2021 17:08
Chinedukin
Chinedukin
26 Oct 2021 17:08
Hello everyone, I have been experiencing some issues with the soft-close drawer systems in my Ikea Metod kitchen for a while now. Specifically, some drawers no longer close smoothly; instead, they slam shut or remain half open. The mechanism seems to be damaged, even though the drawer slides aren’t completely loose or bent. My question is: How can I properly repair these soft-close systems in Ikea Metod? Are there specific replacement parts that need to be changed, or is an adjustment often sufficient? I would appreciate detailed advice on how to proceed, especially on how to disassemble the system, identify defective components, and replace them without having to dismantle the entire cabinet. Thanks in advance for your tips!
Eleanor
26 Oct 2021 17:17
Chinedukin schrieb:
How can I properly repair these soft-close systems on Ikea Metod cabinets?
First, check if the damper on the drawer slide mechanism is still intact. If not, replace it with an original spare part from Ikea. Usually, this is enough to restore the soft-close function.
lorena
27 Oct 2021 09:43
Chinedukin schrieb:
How can I properly repair these soft-close systems on Ikea Metod? Are there specific replacement parts I need to swap out, or is adjustment often sufficient?
When repairing the soft-close drawers on Ikea Metod, it is important to identify the exact soft-close model. Ikea uses various damping systems for Metod, mostly the so-called ‘BLUMOTION’ mechanisms from Blum.
Steps for repair:
- Remove the drawer from the cabinet box: usually by releasing the locks on the drawer slides (pressing locking clips or flipping levers).
- Check the soft-close damper: a common fault is a broken plastic lever or leaking damping fluid.
- Replacement parts can be obtained directly from Ikea online or in-store – ideally using the original item number.
- For adjustment: make sure the drawer slides are securely mounted and that the adjustment screws for lateral and height alignment are set correctly.
- Clean before reinstallation to remove dirt and dust from the rails.
If the damping is only weak, the mechanism can sometimes be lightly lubricated with a fine silicone spray – but avoid oils that are sticky or attract dirt.
Do you have any specific damage to the visible parts? What exact issues does the system show – does it stay open permanently or close too forcefully?
Davidleo
27 Oct 2021 13:56
I had the same problem recently, and replacing the damper worked wonders for me! 😊 I can only encourage you to give it a try—it’s not rocket science, and Ikea replacement parts are affordable.
What I found very important was to remove the drawer properly—first release the clip, then carefully pull it out and replace the damper. After that, the drawer runs smoothly again! It’s really great to be able to fix something yourself after a while instead of having to buy everything new! 🎉
Fitigu
28 Oct 2021 08:22
lorena schrieb:
Ikea uses different damping systems for Metod, mostly the so-called ‘Blumotion’ mechanisms from Blum.
That is correct. Additionally, it should be noted that these dampers are usually molded parts with built-in hydraulic damping, which cannot be repaired. Therefore, the entire damper module must be replaced.
Before replacing, I also recommend checking the drawer for proper alignment of the drawer slides. Loose fittings or dirt can cause malfunctions that may be mistakenly attributed to a damper defect.
For removal and reinstallation of the drawer, Ikea itself advises pressing the release clip on the drawer slide to remove the drawer. In the spare parts shop, using the article number “Metod Soft-Close Damper,” the available modules are listed.
The recommended steps and precautions:
- Completely unload the drawer
- Press the release on the drawer slides
- Replace the damper
- Check alignment and height adjustment
This systematic approach ensures the root cause of the problem is properly resolved.
