ᐅ How can I remove water stains from MALM surfaces?
Created on: 25 May 2024 09:23
barkeo67
barkeo67
25 May 2024 09:23
I have a question regarding the removal of water stains on IKEA Malm furniture surfaces, especially the white lacquered version. These are typical water marks caused by standing cups or small splashes. Some stains appear only superficial, while others seem to penetrate the surface slightly or have left a faint discoloration.
I’m interested in which methods work best in practice to remove these stains without damaging the surface or making the finish dull or cloudy.
Are there any special cleaning products, home remedies, or procedures you would recommend? I have read that sometimes a light polish can be effective, but I’m unsure what is advisable for MALM furniture.
It would also be helpful to know about any potential risks to watch out for and which approaches should definitely be avoided.
Thanks in advance for your tips and experiences!
bapar
25 May 2024 11:07
Hello barkeo67,
Your question is very well phrased, which makes the answer easier.
Water stains on MALM surfaces usually occur due to moisture penetrating beneath the paint layer or causing the surface to become dull. Since these furniture pieces are typically coated with a thin white varnish, caution is advised.
First, I recommend identifying the type of stain precisely: Is it just a superficial lime or water film, or has the water already affected the paint layer?
For superficial stains, you can try gently wiping with a slightly damp microfiber cloth and very mild dish soap. The cloth should be damp, not wet, and the stain should be wiped carefully, not rubbed.
barkeo67 schrieb:
Some stains seem only superficial, others appear to go a bit deeper into the surface
If the stain is deeper, a fine abrasive pad with very low grit (e.g., 0000 steel wool) often helps. However, use this method very carefully and make sure to restore the surface afterwards with a high-quality furniture or clear varnish.
An alternative I recommend is a special furniture polish with paint protection, applied gently with a soft cloth.
But be careful: aggressive cleaners or abrasive products should definitely be avoided, as they can damage the paint surface and cause permanent dullness.
I have a few questions: How old are the furniture pieces? Are the stains dried or still fresh? And how often has the furniture been cleaned so far?
This way we can really find the best method.
Paunon
25 May 2024 13:16
First, wipe gently with a damp cloth and mild soapy water, avoiding rubbing. If the stains persist, try using a cloth with vinegar water (1 part vinegar, 3 parts water). Then immediately wipe with clean water and dry to protect the finish.
Nabla64
26 May 2024 08:39
I would like to provide a more detailed post on how to safely and effectively remove water stains from MALM surfaces. My approach serves as both an explanation and a step-by-step guide:
1. Preparation: Dust and coarse dirt must be removed from the furniture first. A dry microfiber cloth works well.
2. Cleaning with a mild soap solution: Mix warm water with a small amount of mild dish soap. Use a soft, slightly damp cloth—dip it briefly, wring it out thoroughly, and gently wipe the water stains. It is important not to press too hard or scrub.
3. Vinegar solution as a home remedy: For stubborn lime stains, a solution of 1 part white vinegar to 2 parts water can help. Vinegar is acidic and should be used very carefully. Always test the solution on an inconspicuous area, as incorrect use can dull the finish.
4. Immediate drying: After any wet cleaning, wiping dry quickly is essential to prevent moisture from penetrating the surface.
5. Polishing: If the surface has become dull, a gentle furniture polish or a special lacquer care product for white lacquered surfaces can help restore the shine.
6. Avoid abrasive cleaners: Never use aggressive cleaning agents or scouring pads. These permanently scratch the finish.
bapar schrieb:
If the stain is deeper, a fine abrasive sponge with very low grit (e.g., 0000 steel wool) often helps. But only with utmost caution
It should also be mentioned that this method is really only suitable for experienced DIYers and should be tested on inconspicuous areas first.
If you like, feel free to provide more details about the stain removal, such as how old the stains are or whether you regularly maintain the piece of furniture. This way, more precise recommendations can be given.
I hope this helps you! 🙂
