ᐅ How can I clean MALM furniture in an environmentally friendly way?
Created on: 12 Dec 2018 08:47
Avniri
Avniri
12 Dec 2018 08:47
Hello everyone, I own several MALM furniture pieces from IKEA and would like to clean them in the most environmentally friendly way possible. My main concern is to avoid using harmful chemicals that could damage the surfaces or be harmful to the environment and my family. Does anyone know of gentle cleaning methods or household remedies that are especially suitable for the coated surfaces of the MALM series? It would be helpful if you could also explain the proper procedure to prevent streaks or damage. Thank you in advance!
barle
12 Dec 2018 09:13
It is best to simply use a soft, slightly damp microfiber cloth. For tougher dirt, use some diluted vinegar water, but avoid any abrasive cleaners. Afterwards, wipe dry thoroughly.
figata
12 Dec 2018 10:05
The MALM furniture is made of melamine-coated chipboard, which is sensitive to harsh cleaning agents. Therefore, I recommend using only pH-neutral cleaners or a solution of water with a splash of vinegar. A microfiber cloth is ideal to avoid scratches. It is important not to use too much liquid, as it can penetrate the edges and cause swelling.
kulau
12 Dec 2018 11:27
Here is a detailed guide for an environmentally friendly and gentle cleaning of MALM furniture:
1. Preparation: First, carefully remove dust with a dry microfiber cloth. Microfiber cloths ensure that no abrasive particles remain on the surface.
2. Cleaning agents: For light dirt, clear water or a mixture of warm water with a splash of lemon juice or vinegar is sufficient. Many also recommend a few drops of liquid castile soap (without additives) dissolved in water.
3. Cleaning: The cloth should be damp, not wet. Avoid excess moisture to prevent water damage, especially on edges. Clean surfaces gently without rubbing.
4. Drying: Wipe with a second, dry microfiber cloth to remove remaining moisture and avoid streaks.
Additionally, I advise against using abrasive cleaners or acetone-based products as they can damage the surface. If you have questions about the exact composition of the cleaning agents you use, I’m happy to help.
Avniri
12 Dec 2018 12:08
kulau schrieb:
Lemon juice or vinegar
Are these home remedies also safe to use on coated surfaces? I have sometimes read that vinegar might damage the finish. Is this true, or does it only apply to solid wood? I’m curious about how much protection the surface coating provides in this regard.
figata
12 Dec 2018 12:56
Vinegar in diluted form (max. 5% acidity, heavily diluted with water) usually does not damage the melamine coating. Concentrated vinegar or prolonged contact could cause problems. Since MALM furniture has a plastic coating, it is relatively resistant to acid, but as with many materials, the rule applies: short application, immediate wiping, and no exposure time. Solid wood reacts more strongly, but this is not an issue in your case.
