ᐅ How can I clean Malm furniture in an environmentally friendly way?
Created on: 27 Jun 2022 08:34
NarkeHello everyone,
I’m hoping there are some experienced furniture owners here. I have several Malm pieces from Ikea at home and want to clean them as sustainably as possible, without using harsh chemicals or disposable products. Therefore, I’m interested in how you clean your Malm dressers and nightstands in a way that doesn’t damage the surfaces while still being environmentally friendly. Are there any special home remedies or care methods you would recommend?
The surfaces are melamine-coated, so not solid wood, and I’m concerned that some products might damage the coating. I’m really open to tips that are both effective and gentle. Thanks in advance!
Hello Narke,
It’s good that you mention the surface of the Malm furniture. Melamine-coated surfaces do require gentler cleaning than wood or lacquered finishes. My advice is to wipe the furniture with a slightly damp microfiber cloth—without using harsh cleaners.
For everyday dirt, warm water with a small amount of mild dish soap is usually enough. Important: Always dry thoroughly afterward to prevent moisture from seeping into the edges.
If you encounter tougher stains, you can mix some vinegar with water (about 1:5)—this works as an antibacterial cleaner and helps remove water spots or light lime deposits. However, always test on an inconspicuous area first!
One more tip: Avoid abrasive sponges or cleaners to prevent scratching the coating.
JAMESONB4127 Jun 2022 09:12Vinegar water or a mild all-purpose cleaner, microfiber cloth, no abrasive sponges, done.
fikeo schrieb:
For everyday dirt, warm water with a splash of mild dish soap is often enough.I can only confirm that! I usually keep it as simple as possible and always use a soft cloth. 😊 If it gets sticky, a vinegar solution works great.
And hey, Malm furniture is sturdy, but still, take care not to scrub it like the Hulk – that way the surface stays nice for longer! 😉
Interesting that vinegar is recommended. But is it really safe to use vinegar on melamine-coated surfaces without any concerns?
I have read that acetic acid can damage the material depending on the concentration. Are there reliable sources or practical experiences that confirm or refute this?
Otherwise, mild cleaners and microfiber cloths are probably the best standard. But for stubborn stains? What is the best approach here to avoid damaging the material?
Victor54 schrieb:
Is it really safe to use vinegar on melamine-coated surfaces?Good question! Diluted vinegar (not pure) is generally considered safe by many, as the acid is diluted and exposure time is short. A recommended mix ratio is 1 part vinegar to 4-5 parts water. Important: never let it sit for long and wipe off as quickly as possible.
If you have very sensitive areas, testing on an inconspicuous spot before cleaning larger surfaces can help.
Here is a note from Ikea customer service: They recommend mild, neutral-based cleaners and advise against strong acids or alkalis, as these can damage the surface. So vinegar water is more of a practical home remedy, not an official recommendation.
If you want to be extra cautious, stick to plain water with a little dish soap.
