ᐅ How can I remove stickers from Ikea BESTA furniture without causing any damage?
Created on: 14 Mar 2015 08:42
Neokar
Neokar
14 Mar 2015 08:42
Hello everyone, I have some Ikea Besta furniture pieces with stickers on them that I would like to remove without damaging the surfaces. The furniture has a smooth, painted or melamine resin-coated surface, which can be sensitive. Does anyone have experience or tips on how to gently remove stickers or their adhesive residues without causing scratches or dull spots? It would also be important to know whether home remedies are suitable or if special products are necessary. Thank you for any help!
DINASAN
14 Mar 2015 13:27
Hello Neokar,
First of all, your question is very relevant because many people underestimate how sensitive the surface of Ikea BESTA furniture can be. The melamine resin-coated surface reacts differently to mechanical impact and solvents. I will briefly outline some practical steps:
- I recommend starting by gently testing with warm water and a soft cloth to see if the sticker can be easily removed.
- If that is not enough, heating it with a hairdryer often works. The heat softens the adhesive slightly, allowing you to carefully peel off the sticker. Caution: Do not use too much heat to avoid damaging the surface.
- To remove any adhesive residue, oil (e.g., cooking oil or baby oil) is suitable – soak it on, let it sit briefly, then gently rub off with a microfiber cloth, not a scouring pad.
- Alternatively, special adhesive removers can be used, but test carefully on an inconspicuous area first, as some solvents might cause the surface to become dull.
- Please do not scrape with sharp objects under any circumstances, as this will always damage the surface.
One more question: Could you describe what kind of stickers these are? For example, are they price labels, decorative stickers, or manufacturer tags? Some adhesives are more aggressive than others.
I hope this helps you for now!
Tekuko
14 Mar 2015 16:59
DINASAN schrieb:
The heat softens the adhesive slightly, allowing you to carefully peel off the sticker. Warning: Do not set the temperature too high to avoid damaging the surface.
Exactly like that. Turn on the hairdryer, warm the adhesive, and the sticker will come off more easily. Avoid applying pressure when removing it.
nedagla
15 Mar 2015 09:14
Oh yes, I had the same problem and I’m so happy I managed it without any scratches! 🙂
My tip: After warming it up with a hairdryer, I applied baby oil to a cotton cloth and rubbed the adhesive residues with it. Then I let it sit for a while and wiped it off very carefully. The surface looked like new afterward!
Go for it, it really works well—just be patient and don’t scrub. Good luck!
Neokar
16 Mar 2015 11:02
nedagla schrieb:
After warming it up with a hairdryer, I applied baby oil to a cotton cloth and rubbed the adhesive residues with it. Then I let it sit for a bit before gently wiping it off.
Thanks for the tip, that sounds much gentler than using chemical removers. I will try the hairdryer and baby oil method.
[@DINASAN] Thanks for asking! These are mainly price tags that have been stuck on for quite a while – so the adhesive seems really stubborn. Is there anything specific to watch out for with older adhesives like these?
Also, how long should the oil ideally be left to soak in before wiping? I really don’t want to take any risks.
