ᐅ How can I quickly repair a faulty IKEA Metod drawer?
Created on: 24 Jul 2022 08:23
Duchen5
Duchen5
24 Jul 2022 08:23
Hello everyone, I have an IKEA Metod drawer that hasn’t been closing properly for a few days and sometimes gets stuck when opening or closing. Specifically, it’s the bottom drawer of my kitchen unit, and the problem occurs when closing, as the drawer seems to misalign or the slide mechanism is no longer working smoothly. This needs to be fixed quickly and as easily as possible since I use the kitchen daily and don’t want to risk the condition any longer. Does anyone have experience with this and can recommend a practical, quick solution to repair this Metod drawer myself? I would appreciate any tips on what to specifically check—such as whether it could be the drawer slides or maybe the drawer front is loose. Thanks!
PLOMA
24 Jul 2022 10:12
Hello Duchen5,
If your Metod drawer sticks or doesn’t close properly, it’s usually due to the runner or the alignment of the drawer itself. Here is a step-by-step suggestion to address the issue precisely:
- First, completely empty the drawer and carefully remove it. IKEA Metod drawers often have a release mechanism on the runners, usually small levers you need to press simultaneously to detach the drawer.
- Then, check the runners inside the cabinet and on the drawer. Pay special attention to the rollers or ball bearings, which allow smooth movement. These are often blocked by dirt or the rollers can be slightly damaged.
- Next, inspect the screws that secure the runners and the drawer front. Loose or misaligned fasteners can cause the drawer to jam.
- Clean all moving parts with a dry cloth and optionally use some silicone spray to keep the mechanism smooth. Please do not use oil on wood surfaces, as it only attracts dirt!
- After that, carefully put the drawer back in, making sure it slides straight into the runners.
Could you describe more precisely whether the drawer sticks when closing or rather when opening? Have you already checked if the runners are bent or if there are foreign objects in the area? That would help to analyze the problem more specifically.
Rashadmeo
24 Jul 2022 11:47
PLOMA schrieb:
Clean all moving parts with a dry cloth and optionally a bit of silicone spray to keep the mechanism running smoothly
Really great tip, that often makes all the difference! 😊😊
I recently had a similar issue and was able to get the drawer running smoothly again with a bit of care and a spray of silicone lubricant. Just remove the drawer, clean everything thoroughly, make sure no lint or small stones are left inside, and then put it back in.
Don’t hesitate to give it a try – the Metod drawers are actually quite sturdy, and if you know what to look for, the repair is really quick and doesn’t require any special tools! 👍
sobau
24 Jul 2022 12:36
Problem solution here:
- Completely remove the drawer.
- Check the tracks for dirt and alignment.
- Inspect screws on the tracks and front panel and tighten if necessary.
- Lightly spray the guides with silicone spray.
- Reinsert the drawer, ensuring it is inserted straight.
This should resolve most issues.
Jukin
25 Jul 2022 09:05
Duchen5 schrieb:
Specifically, it concerns the lower drawer of my kitchen unit, and the problem occurs when closing, as the drawer seems to jam or the slide mechanism no longer operates smoothly.
This very much sounds like the drawer slides have slipped out of alignment. With Metod drawers, the issue often arises because the screws loosen over time due to daily use, causing the slides to sag slightly or become misaligned.
My advice: Retighten all the screws on the drawer and the metal slides, including the screws fixing the slides to the cabinet frame. Use a Phillips screwdriver for this.
I also recommend checking if any slide is bent or damaged. Small dents or deformations immediately affect how smoothly the drawer glides and closes, and if replacement isn’t possible, these can sometimes be carefully corrected with a small hammer.
If you want, I can also provide detailed instructions on how to properly remove and reinstall the drawer—this way you can quickly check if that solves the problem.
