I’m facing the issue that my Pax wardrobe is located in an apartment where it can sometimes get quite humid – especially in winter, I notice increased moisture levels that occasionally affect the inside of the wardrobe. My question is: How can I effectively protect my Pax wardrobe from moisture so that the wood and especially the stored clothes are not damaged by mold or moisture?
I would appreciate practical tips that can be implemented without major renovations. I am particularly interested in measures to improve air circulation, possible moisture absorbers, or other solutions that have proven effective in everyday use.
Thank you in advance!
mardo1 schrieb:
I am especially interested in measures for air circulation, possible moisture absorbers, or other solutions that have proven effective in everyday use.To be honest, I find that many traditional moisture absorbers often act like a placebo. Sure, they absorb some water, but the problem usually remains because the root cause is ignored: poor ventilation or too much moisture coming from outside.
If the Pax wardrobe is placed directly against a cold exterior wall, treating just the inside won’t help much. In that case, it would be better to consider insulation or at least some distance from the wall.
However, the question remains: do you really want a wardrobe standing in a damp corner? Sometimes it’s better to change the location rather than constantly dealing with problems that can’t be solved sustainably otherwise.
likuken schrieb:
If the Pax wardrobe is placed directly against a cold exterior wall, it’s not very effective to address the issue only from the inside.That is partially true, but there are some simple and cost-effective measures to protect the Pax wardrobe from moisture, even if it is against a problematic wall.
- Allow a small gap between the wardrobe and the exterior wall, ideally at least 2-3 cm (1 inch). This improves air circulation.
- Moisture absorbers like silica gel or zeolite can help reduce humidity inside the wardrobe, especially when combined with regular ventilation.
- Use breathable garment covers inside the wardrobe, avoiding plastic sheets or airtight bags.
- Occasionally use a dehumidifier or at least a hygrometer to better monitor the moisture levels.
Of course, these steps do not replace proper moisture control in the rooms themselves, but often such measures can significantly improve conditions inside the wardrobe.
warrenka5714 Nov 2024 10:03mardo1 schrieb:
How can I effectively protect my Pax wardrobe from moisture, so that the wood and especially the stored clothes are not affected by mold or moisture damage?I’m very familiar with this issue, as I struggled for years with damp living spaces. What helped me a lot—probably also psychologically—was taking the causes seriously by ventilating regularly: opening windows fully three times a day for 5 minutes each time without heating on makes a big difference.
Additionally, I installed small hygrometers inside my wardrobe to monitor the humidity levels. When it gets too high, I sometimes turn on a small electric dehumidifier—not the most environmentally friendly option, but it prevents mold.
And very important: I store clothes in breathable garment bags, not airtight plastic bags. This stops moisture from accumulating behind the clothes.
Maybe you can find a good balance of measures that are easy to implement in your daily routine!
