ᐅ How do I properly install IKEA Metod baseboards?
Created on: 10 May 2015 09:37
manasim44
manasim44
10 May 2015 09:37
I am currently facing the task of properly installing IKEA Metod baseboards on my new kitchen and am looking for a detailed guide or tips to do it correctly. Although the IKEA instructions describe some steps, I find them rather brief regarding the attachment of the baseboards.
I am especially interested in:
- Which installation methods are recommended to ensure the baseboards are securely fixed and do not loosen over time?
- Should the baseboards be simply snapped in, or is it advisable to also screw or glue them?
- If screws are used, what type and size are ideal, and how should drilling into the baseboards or the wall be done to avoid cracking or damage?
- Are there any special tools or materials that make the installation easier?
I would appreciate it if experienced DIYers or professionals could share their practical tips or experiences with attaching IKEA Metod baseboards. Thanks in advance!
Enrico4
10 May 2015 11:22
- Which installation methods are recommended to ensure that baseboards stay firmly in place and do not become loose over time?
- Should baseboards be only snapped in place, or is it advisable to also screw or glue them?
- If screws are used, what type and size are ideal, and how should drilling into the baseboards or walls be done to avoid cracks or damage?
- Are there any special tools or materials that make installation easier?
The Metod baseboards from IKEA are designed to be simply snapped into place under normal circumstances, allowing for easy and tool-free installation. However, based on experience and to ensure long-lasting stability, I recommend the following approach:
- Use the supplied clips to secure the baseboards under the kitchen cabinets. The clips should be installed every few tens of centimeters (inches).
- If the wall is uneven or the baseboard is very long, additional fastening with small screws (e.g., countersunk screws 3.5 x 20 mm (about 1/8 x 3/4 inch)) can be used. Screw the screws through the clips into the cabinet wood or back panel, not directly into the wall.
- Drilling into the wall is usually not necessary and can cause cracks, as the kitchen structure itself supports the load.
- Recommended tools for installation include a cordless drill with depth stop, a spirit level for alignment, and optionally a utility knife for any finishing work.
Snapping the baseboards in place alone holds well if properly prepared. For extra security, the screwing method is the best addition.
Parmin
11 May 2015 08:44
Enrico4 schrieb:
Clicking them in alone holds well if the preparation is done correctly.
I don’t fully agree with that. Sure, IKEA has a clever system, but especially with uneven floors or moisture, for example near a sink, these clips can become loose over time. That’s why you should consider whether clicking alone is really enough, especially since baseboards need to withstand a certain amount of stress.
manasim44 schrieb:
Should baseboards only be clicked in, or is it advisable to also screw or glue them?
In practice, I wouldn’t recommend just one method, but a combination:
- firmly click the baseboards into place
- additionally, install small screws at inconspicuous points offset from the clip attachments
- alternatively or in addition, use solvent- or silicone-free mounting adhesives that remain load-bearing after drying
This also reduces vibrations that can damage the clips over time. My recommendation: don’t rely solely on IKEA’s system, but ensure safety with your own securing measures.
Sepele
12 May 2015 14:03
I would like to add a brief guide based on my experience that helps when attaching the IKEA Metod plinths:
- Preparation: The base kitchen cabinets should be precisely aligned and level. Small unevenness in the wall will affect the installation later.
- Attaching the clips: These are fastened to the underside of the cabinets with the supplied screws (usually 3.5x15 mm (0.14x0.59 inches)). It is important to install them at intervals of about 30 cm (12 inches). Additional clips at the ends increase stability.
- Clicking in the plinths: The plinths are shaped on the back to easily snap into the clips. Precise alignment is crucial here.
- If the wall is uneven or the plinths catch when snapping in, the clips can be slightly adjusted or shimmed with washers.
- In cases of high humidity or tension, it is advisable to use construction adhesive on the inside of the plinth to ensure extra hold. Apply the adhesive sparingly and in small spots.
- Tools: Cordless drill with precise torque setting, spirit level, tape measure, and if necessary, fine sandpaper for touch-ups.
This procedure helps achieve a professional result and reduces the need for repairs later. If you want to be on the safe side, additional screws in inconspicuous places are not a disadvantage.
