ᐅ How do I properly install Ikea Metod baseboards in the corners?
Created on: 24 Jan 2018 08:43
ixgauHello everyone,
I recently started installing an IKEA Metod kitchen and am currently facing the issue of joining the plinth boards cleanly and securely in the corners. Specifically, I’m looking for the proper way to connect the Metod plinth boards in internal corners so that they align flush without any unsightly gaps. Are there special connector pieces or recommended methods to install the plinths precisely? I was thinking of some kind of miter joint or overlap but am unsure how this is actually intended for Metod and whether there are any particular details to consider. I would appreciate tips, step-by-step instructions, or shared experiences that can help me install the plinth boards professionally.
ixgau schrieb:
Are there special connectors or a recommended method for mounting the baseboards precisely?There are special corner connectors made by IKEA for the Metod baseboards. The baseboards are cut and connected at the inside corner using the corner connector. It is important to saw the ends at a right angle so that everything fits flush.
I have installed several kitchens using Metod kickboards and can share some details that might be helpful for many.
First: It’s best to use the Metod kickboards with the original corner connectors from IKEA, as these are specifically designed for the system. They are small plastic parts that fit into the profiles of the boards, ensuring a stable connection.
For internal corners, it is important to measure and cut each board precisely. They are usually cut straight at a 90-degree angle rather than mitred, so both boards meet end-to-end on the corner connector. Mitre cuts are generally not recommended for Metod because the connector won’t fit properly. Therefore, never cut at an angle.
Procedure:
- Measure the length up to the corner very accurately.
- Cut the kickboards straight with a fine saw, ideally a miter saw or crosscut saw.
- Insert the corner connector into the groove at the end of one board.
- Then attach the second board at a right angle onto the connector.
- If necessary, clamp the connection until any adhesive (if used) has dried.
Another tip: If the walls are not perfectly square, a small gap may remain. In this case, you can use some silicone or acrylic paint to make the finish look neat.
To assist you better: How accurate are your walls? Are they really at right angles? Have you already obtained corner connectors? What tools do you have available?
Without these details, it’s difficult to recommend a perfectly fitting solution.
Procedure:
PIN66 schrieb:
It’s best to use the Metod baseboards with the original IKEA corner connectors, as they are specifically designed for this system.Exactly, the original connectors are crucial here to ensure stability and precision.
I also recommend working precisely when cutting: use a fine-tooth saw or miter saw with a stop strip to achieve a clean and square cut edge. This greatly simplifies the assembly.
Additionally, during installation, make sure to dry-fit the baseboards before securing them permanently. This allows you to check for an accurate fit and identify any discrepancies early on so adjustments can be made.
Tip: If the baseboards meet irregular or slightly non-square corners, small filler pieces can help mask gaps, or you can use a minimal amount of acrylic filler as a visual aid.
If possible, install the baseboards at the end of the kitchen installation to avoid damage or misalignment caused by earlier work.
tra_nina schrieb:
I also recommend working precisely when cutting: use a fine-tooth saw or a miter saw with a cutting guide to ensure the cut edge is clean and square.Exactly, that’s the key. If the cut edge isn’t perfectly accurate, the connector won’t fit properly.
Simply cut the corner square, slide in the connector, and assemble. It fits firmly and effectively covers minor irregularities.
