ᐅ How do I properly align the sliding doors of the Ikea Pax wardrobe?
Created on: 6 Feb 2024 10:13
nicola
nicola
6 Feb 2024 10:13
I am currently facing the challenge of aligning my Ikea Pax sliding doors so that they operate smoothly and close flush. However, I have noticed that I cannot adjust the doors perfectly – sometimes they rub or do not close properly.
I am specifically interested in how to correctly align the Ikea Pax sliding doors so that they run steadily on the track without sticking or hanging unevenly.
It is important for me to know the exact steps to follow in order, whether any specific tools are needed, and if there are special tips to avoid common alignment mistakes.
Also: Are there any differences in the alignment process depending on whether it is a 2-door or 3-door Pax version?
I look forward to your experiences and tips, especially detailed instructions or advice on hidden adjustment options.
Thanks in advance!
fredle
6 Feb 2024 11:22
Hello Nicola,
I will address your question step-by-step and provide a clear guide on how to properly align the Pax sliding doors:
- First, make sure the wardrobe itself is sturdy and level. The wardrobe frame must be completely straight; otherwise, the door will always stick.
- Place the doors onto the top track and then gently snap them onto the bottom track. Be careful: the bottom track prevents the door from tipping forward.
- Each door has adjustment screws on the top that allow you to adjust the height. Use these screws mainly to align the door vertically.
- Next, use the side adjustment screws on the rollers to move the door horizontally and align it with the adjacent doors or the wardrobe frame.
- Ensure that the rollers move freely and are not dirty. Sometimes dirt blocks smooth operation.
- For multi-door systems, such as a three-door version, it is important to adjust the middle door so that it does not catch on the neighboring doors when closing. For this, definitely use both the side and height adjustments.
Common mistakes:
- Doors are not hanging straight because the wardrobe is uneven.
- Rollers are dusty or damaged.
- Adjustment screws are incorrectly used or not adjusted enough.
Finally, I recommend sliding the doors gently back and forth a few times after adjusting them to check that everything runs smoothly.
If you still have an issue, feel free to describe more precisely where it sticks or does not operate well.
Best regards!
Surela
7 Feb 2024 08:47
Hello Nicola,
I find your question interesting because proper alignment of Pax sliding doors is often underestimated, causing unnecessary frustration for many. I want to go into a bit more detail here so you know exactly what to consider when adjusting them.
1. Preparation: Make sure to check the floor and the position of your Pax wardrobe. An uneven floor means you'll be trying to align doors on a slanted surface later—which almost never works well in the long run. Use a spirit level and try to level the wardrobe with small shims or cork pads.
2. Door Mechanism: Each Pax sliding door has rollers at the top that move within the upper track, and a lower track with small guide rollers or guide clips.
3. Adjustment Screws:
- Usually, there are two adjustable screws at the top: one for vertical height, one for horizontal position (depending on the model you have). Turn them slowly with the supplied tool.
- The lower track is less frequently adjustable, but it’s important to check the guide rollers to make sure they are not bent.
4. Tips for 3-door Systems:
- The middle door should run slightly ahead of the side doors; otherwise, it presses too hard and may get stuck.
- Make sure the doors don’t hit the guide groove at the same time—that maximizes smooth operation.
5. Special Notes:
- If the doors don’t close properly despite adjustment, it might be due to incorrect installation of the tracks.
- Sometimes using a small amount of silicone spray to lubricate the tracks can help reduce friction.
I’m curious what tools you have used so far to adjust the doors and whether the wardrobe is perfectly level. Often, people lack a clear reference and lose the sense of a straight alignment when making adjustments.
The process can be a bit time-consuming but is definitely worth the effort.
Good luck!
fredle
7 Feb 2024 14:06
Surela schrieb:
I’m curious which tools you have used so far to adjust the doors, and whether the wardrobe is perfectly level? Often, when adjusting, there is no reference point, and the “feel” for a straight position is missing.
Good point! Here are some additional tips regarding the tools:
- Usually, your Pax set includes a small hex key (Allen wrench) needed to adjust the set screws.
- To check alignment, definitely use a spirit level or a laser level. If you don’t have one, a smartphone with a leveling app will also work.
- A small screwdriver can help to remove any existing cover caps.
With these tools, you can work precisely. I also recommend making rough adjustments on one door first, then completing the fine tuning after several test runs.
Also, a tip: Don’t force the doors if something won’t move; instead, double-check if anything is blocking the mechanism.
Hope that helps!
lyndon
8 Feb 2024 09:33
fredle schrieb:
Typical mistakes:
- Doors are not aligned properly because the wardrobe is crooked.
- The adjustment screws are used incorrectly or not enough.
In addition to these points, I would like to add the following:
- When aligning the Ikea Pax sliding doors, it is very important to ensure that the doors are not pressed too tightly against each other. This can not only cause jamming but also place excessive mechanical stress on the rollers, leading to long-term wear.
- Sometimes it helps to check each door individually with a spirit level after adjustment to ensure they are truly vertical. This is the only way to guarantee the closing mechanism works optimally.
- The track systems are usually made of metal and should be regularly inspected for damage. Small unevenness or bent corners can significantly affect the smooth sliding of the doors.
If the doors still do not operate optimally despite careful adjustment, it is advisable to replace the rollers if replacements are available. Ikea offers spare parts.
In short: patience and attention to detail are key for long-term functionality.
