ᐅ How can I prevent squeaking in Ikea Metod drawers?
Created on: 23 Oct 2023 08:37
Rapau
Rapau
23 Oct 2023 08:37
I recently installed a kitchen with Ikea Metod drawers and unfortunately noticed that some drawers squeak quite loudly when opening and closing. Since this can be annoying over time and I’m concerned that it might put extra strain on the mechanism, I would like to know how to reliably prevent this squeaking.
I am especially interested in whether there are any specific maintenance or lubricants that can be safely used without damaging the plastic or metal parts. Tips on proper cleaning or installation aids would also be welcome if they can help avoid the squeaking.
Thanks in advance for your experiences and advice!
DUVIN
23 Oct 2023 09:12
Lubricating with silicone spray or Teflon spray usually works very well.
Simply spray it on the sliding rails, then open and close the drawer a few times to distribute the lubricant evenly.
Matthewt48
23 Oct 2023 09:58
Hello Rapau,
I understand your concern well; squeaking is not only annoying but can also indicate mechanical wear. Here are some basic tips that might help:
- First, thoroughly clean the drawer slides and rollers, as dirt or dust often causes squeaking.
- It’s best to use silicone spray, as it is safe for plastic and does not become sticky.
- Avoid WD-40 or other oily products, which can attract dust and affect the mechanism.
- Check if the drawers are properly aligned – incorrect installation can cause friction.
If you want, I can also explain in more detail how to disassemble the drawer to inspect the mechanism.
LOGEMIN
23 Oct 2023 11:23
I would like to add a brief guide on how to systematically prevent squeaking in Ikea Metod drawers:
1. Cleaning: Make sure to remove all dirt and debris from the drawer slides and rollers. A dry cloth or slightly damp cloth works well for this. Avoid using oily or greasy cleaners.
2. Alignment check: Misalignment often causes extra friction. Check if the drawer and slide are properly installed.
3. Lubrication: For Metod drawers, I recommend silicone spray because it does not damage the plastic parts. Spray sparingly on the slides and rollers, then slide the drawer in and out several times to distribute the lubricant evenly.
4. Alternative: If silicone spray is not available, dry lubricants like Teflon powder can also help, as long as it is applied directly to the slide areas.
5. Avoid oils or greases that can become sticky and attract dust.
Summary: Squeaking is usually caused by friction between plastic parts due to insufficient maintenance. Regular cleaning and the appropriate lubricant will prevent it effectively.
Rapau
24 Oct 2023 14:45
Matthewt48 schrieb:
Avoid WD-40 or other oily products that can attract dust and affect the mechanics.
Thanks, that’s very helpful. I actually had WD-40 at home and wasn’t sure if it was okay to use.
LOGEMIN schrieb:
Lubrication: For Metod drawers, I recommend silicone spray, as it does not damage the plastic parts.
Could you please tell me how to recognize if a silicone spray is really suitable for plastic before buying? Are there any brands or specific terms I should look out for?
Also, with two of my drawers, the squeaking occurs irregularly—sometimes only after several days. Could this be because the lubricant spreads out or evaporates? Would regular maintenance at longer intervals be enough, or should I lubricate more frequently?
Lotizar
25 Oct 2023 07:59
Hello Rapau,
Regarding your question about silicone sprays: When purchasing, make sure the packaging explicitly states "suitable for plastics" or "plastic compatible." Products that are specifically designed as lubricants for plastic and metal connections are especially suitable.
About durability: Silicone spray is volatile, it evaporates slowly and does not attract dust. However, it can fade over time, especially if drawers are frequently moved. Therefore, maintenance every few months is recommended, depending on usage frequency.
Brief summary:
- Check for "plastic compatible" on the packaging
- Maintenance every 3–6 months
- More frequent maintenance if used heavily
A perfect sealing of the runners or preventing moisture can also contribute to longevity.
