ᐅ What tips and tricks can help make IKEA BESTA drawers operate more smoothly and quietly?
Created on: 12 Mar 2019 14:17
PIGINI
PIGINI
12 Mar 2019 14:17
Some time ago, I assembled several IKEA Besta drawers and noticed that opening and closing them is not very smooth and can sometimes be quite noisy. This bothers me a lot, especially when I’m looking for something in the drawers at night.
I’m interested in learning about any tips, tricks, or improvements you can recommend to make IKEA Besta drawers operate more smoothly and, above all, more quietly. I’m curious about simple adjustments as well as minor modifications or alternative materials that could help improve the running quality.
Any advice on experiences with installing damping systems, different drawer slides, or lubricants is also welcome.
Thanks in advance for your tips!
fasau
12 Mar 2019 15:03
Hey, great question! I had exactly the same problem with my BESTA drawers!
What made the difference for me was, first, lightly lubricating the drawer runners with a special silicone spray. This ensures smooth movement without sticking or attracting dust.
Second, I attached small soft rubber bumpers at the drawer stops. These basically absorb the impact and significantly reduce the noise.
Super simple and really effective! Give it a try—you’ll be surprised! 🙂
Espen
12 Mar 2019 15:14
Lubricating the tracks with Teflon spray or silicone oil usually helps.
Also, make sure the drawers are installed with precise alignment.
Samir
12 Mar 2019 15:42
To improve the smooth operation of IKEA BESTA drawers, the following is recommended:
- Check the rail attachments: Loose or slightly twisted rails can cause friction and noise.
- Use silicone spray or graphite powder on the drawer slides.
- Attach soft end stops made of foam or rubber at the ends.
If necessary, in some cases, you can also switch to an alternative sliding system from a hardware store, which often provides better damping and smoother operation.
FAZAR
12 Mar 2019 16:07
To optimize the sliding performance and reduce noise in IKEA BESTA drawers, a multi-step approach is recommended:
- Step 1: Remove the drawers and thoroughly clean the slides. This involves removing dust, dirt, and old lubricant residues, ideally using a lint-free cloth and isopropanol.
- Step 2: Inspect and, if necessary, readjust the slide installation. The IKEA slides are often slightly bent or not mounted perfectly flush on the inside, which can cause sticking. Using small washers for level adjustment can also be helpful.
- Step 3: Apply a suitable lubricant. PTFE-based sprays (e.g., silicone spray with PTFE content) are highly recommended because they do not gum up or attract dust like greasy oils can.
- Step 4: Improve the bump stops: Soft damping pads (made of soft foam or rubber) should be attached to the front stops. These prevent the metallic rattling noise when closing and protect the drawers in the long run.
- Step 5: If the drawers still run unevenly or stick despite optimal care, consider replacing the slides with high-quality under-mount slide systems, which often include a soft-close feature.
One additional note: The material quality of the original BESTA slides is not comparable to more expensive full-extension slides. Therefore, noise development is partly due to manufacturing tolerances. You should feel only minimal resistance when pulling out the drawers; otherwise, there are adjustment errors.
I can also assist if you can provide more detailed information about your drawer type or the load applied!
INGRID34
12 Mar 2019 16:29
I simply glued felt pads to the sides of the drawers. This cushions the impact quite well and significantly reduces noise.
