ᐅ How can I lubricate IKEA BESTA drawers to improve their movement?
Created on: 28 Jul 2018 08:12
petrit47
petrit47
28 Jul 2018 08:12
I have an issue with my IKEA Besta drawers: they no longer slide as smoothly as they did initially, which makes opening and closing quite difficult. I suspect it would help to lubricate the drawer slides somehow, but I’m unsure which oil or lubricant is best to use since I don’t want to damage anything.
My questions are:
- Which oil or lubricant is most suitable for the metal and plastic components of the Besta drawer slides?
- What is the best method for applying the lubricant to avoid stains or build-up of dirt?
- Do I need to fully remove the drawers, or is it enough to lubricate them while still installed?
I would really appreciate any advice or experience you might have to help my Besta drawers run smoothly again without having to remove or replace them. Thanks in advance!
Laure57
28 Jul 2018 08:53
Hello petrit47,
[thank you very much for your very well-structured question.]
For IKEA BESTA drawers, I generally recommend using a light, silicone-based spray or a special furniture spray that is ideal for plastic and metal parts. Mineral oil-based lubricants like machine oil are often too thick and can attract dirt.
You should carefully pull out the drawers to access the slides – but fully removing them is not necessarily required if you can reach them well. It is important to clean the slides thoroughly before lubricating, for example with a lint-free cloth and possibly some isopropanol for degreasing.
After cleaning, apply the spray thinly and then carefully slide the drawer in and out several times to distribute the lubricant evenly. Wipe off any excess oil immediately to prevent stains.
I hope this helps! If you want, I can provide more specific recommendations for certain products.
barge
28 Jul 2018 09:22
Hey petrit47,
just think about it, those good old BESTA drawers need care too, like a fine wine 🍷
Laure57 schrieb:
After cleaning, apply the spray thinly and then gently slide the drawer in and out several times so the oil distributes well.
Absolutely right! And while you’re at it, check the rollers or ball bearings — sometimes they’re the culprit and need a bit of attention too (meaning lubrication 😄).
My secret tip is silicone spray, which provides smooth gliding without the notorious greasy, sticky residue. Just spray a little, let it air out well, and then test it.
And don’t worry – the best glide doesn’t come from bad oils, but from proper maintenance! Good luck!
FABIAN_DEO
28 Jul 2018 10:11
Good morning,
to properly maintain your BESTA drawers, I recommend planning the process a bit more thoroughly. The use of lubricants should be carefully considered, as the drawer slides usually consist of a combination of metal parts with plastic inserts.
Step-by-step instructions:
- Pull the drawer out completely and, if possible, remove it entirely to have full access to all guide components.
- Use a soft brush to remove loose dirt, especially from the slide rails.
- Clean the surface with a dry, lint-free cloth.
- If there are stubborn stains or residue, use a small amount of isopropyl alcohol.
- Since conventional oils can damage or smear the plastic parts, I recommend a specially designed silicone spray or PTFE spray (Teflon-like).
- Avoid spraying too generously to prevent greasy films or dust accumulation.
- Insert the drawer evenly and slowly into the slide, moving it in and out several times.
It would also be helpful to know if your drawers have soft-close or push-to-open mechanisms, as these require special care.
Could you please describe this in more detail or check the exact model designation?
petrit47
28 Jul 2018 10:47
Thank you for your quick and helpful responses.
FABIAN_DEO schrieb:
Could you describe that in more detail or check the exact model name?
This is the BESTA version with soft-close mechanism, meaning the drawer is automatically pulled down gently at the end. This improves comfort, but I’m afraid the mechanism might be affected by the current condition.
The drawers are made of metal with plastic gliders. It is possible to remove them completely, but I only want to do that if absolutely necessary.
A quick question: What exactly is the difference between silicone spray and PTFE spray in terms of application? Are there any risks to the soft-close mechanism if I use the wrong spray?
Laure57
28 Jul 2018 11:08
Good question about the difference between silicone spray and PTFE spray!
Silicone spray is usually a bit more fluid and creates a very smooth surface that works well on all materials without becoming sticky. It is ideal for plastic parts and provides water repellency.
PTFE spray (with Teflon) forms a very thin, dry film that is especially resistant to abrasion and long-lasting. It is somewhat thicker in effect and works very well for metal sliding elements.
For soft-close mechanisms, silicone spray is often sufficient since it leaves fewer residues and does not damage plastic parts. PTFE is a bit more specialized and suits metal-to-metal contact.
petrit47 schrieb:
Are there risks for the soft-close mechanism if I use the wrong spray?
In theory, using the wrong lubricant can cause sticking or attract dirt, which can slow down the soft-close mechanism. Therefore, it’s better to apply sparingly and precisely, and clean beforehand.
