I recently bought a Malm factory-made piece of furniture from IKEA and am really pleased with the design and craftsmanship. However, I am now wondering how to effectively prevent scratches on the surface. These furniture pieces have a rather soft surface finish or oil coating, which is quite sensitive to mechanical wear.
Therefore, my question is: What specific measures—from daily handling to protective products and simple DIY tricks—do you recommend to permanently avoid scratches? Are there any special tips that help better protect the finish or surface?
I would greatly appreciate detailed, practical advice, including any products or methods you personally trust. Thanks in advance!
Karsten4526 Apr 2020 18:57parbla9 schrieb:
Do you have any recommendations regarding the exact cleaning agents?I usually stick to warm water and a soft cotton cloth, occasionally adding a drop of mild dish soap. Never use harsh cleaning agents – that's about it. 😉
feklo schrieb:
Use a mild dish soap solution (a few drops in warm water) but no strong cleaning agentsPerfectly summed up. Sometimes less is more!
NoValentin26 Apr 2020 20:05If you have pets, you should consider their claws. Cats or dogs often like to use melamine surfaces as climbing spots. A blanket or a soft cover can help protect the surface.
Thank you for all the helpful recommendations!
I have another question regarding the use of protective films or surface sealants. Does anyone have experience with whether these are beneficial for Malm furniture, or if they might negatively affect the aesthetics or appearance?
Can films possibly form bubbles if the furniture temperature fluctuates? And what about their durability?
I appreciate any feedback based on your experience.
Regarding protective films and sealants on Malm furniture:
1. Films can provide some protection, but most adhesive films are not ideal for high-gloss or painted surfaces like those on Malm. They can slightly alter the appearance and—as you correctly suspect—may cause bubbles due to temperature fluctuations.
2. Instead of films, I recommend a professional furniture sealant with clear coatings specifically designed for these surfaces. These are not intended for DIY application but last significantly longer and look better.
3. If you prefer a DIY approach: There are also transparent protective varnishes for laminate or melamine furniture that are easy to apply. It is important to choose a varnish that remains flexible and does not become brittle.
Summary: Protective films are a short-term solution; for long-lasting protection, a suitable sealant is better. Films almost always affect the appearance, so I recommend them mainly for pieces of furniture that are less visible in living areas.
I hope this helps!
I hope this helps!
Guyju schrieb:
Visual impairments are almost always present with filmsThanks for the detailed answer, that’s an important point. I have quite light-colored furniture, so slight discolorations or reductions in surface gloss would really be noticeable.
Guyju schrieb:
I rather recommend a professional furniture sealing with clear coatingsSo it’s better to have a specialist come in instead of trying it myself? Are there any criteria about which types of coatings are truly compatible with the Malm surface?
