ᐅ How can I prevent scratches on Malm furniture?
Created on: 26 Apr 2020 18:03
parbla9
parbla9
26 Apr 2020 18:03
I recently bought a Malm factory-made piece of furniture from IKEA and am really pleased with the design and craftsmanship. However, I am now wondering how to effectively prevent scratches on the surface. These furniture pieces have a rather soft surface finish or oil coating, which is quite sensitive to mechanical wear.
Therefore, my question is: What specific measures—from daily handling to protective products and simple DIY tricks—do you recommend to permanently avoid scratches? Are there any special tips that help better protect the finish or surface?
I would greatly appreciate detailed, practical advice, including any products or methods you personally trust. Thanks in advance!
TRA33
26 Apr 2020 18:09
Avoid placing sharp objects on the surface. Use felt pads under lamps or decorations. Keeping some distance from pet claws is also beneficial.
Karsten45
26 Apr 2020 18:12
A little careful handling works wonders! 😊 I also recommend using small pads or placemats to prevent anything from scratching the surface directly. And regularly wiping gently to remove any fine sand or dust, as this is often underestimated.
rubybi
26 Apr 2020 18:21
Good evening,
I would like to summarize a few basic measures that help protect Malm furniture from scratches:
1. Surface care: Use a soft, damp cloth without chemical cleaners – harsh agents can damage the finish.
2. Protective pads: As mentioned before, felt pads under decorations, pots, or appliances are useful.
3. Use placemats and table mats – these provide an additional physical barrier.
4. When cleaning, always wipe gently and follow the grain direction.
5. Avoid direct pressure from sharp objects or pointed tools.
In summary, the goal is to minimize mechanical abrasion on the surface as much as possible.
If there is interest, I can gladly provide recommendations for specific protective products suitable for the surface.
parbla9
26 Apr 2020 18:30
Thanks, that makes sense. Do you use the felt pads only in specific spots, or do you also clean them regularly to avoid unknowingly grinding in dust and small particles?
karsten45 schrieb:
Wipe gently and regularly to prevent fine sand or dust from scratching – this is often underestimated.
Do you have any recommendations regarding specific cleaning agents? I’m worried that some products might damage the finish. Is there a standard cleaning solution for this, or is it better to just use water?
feklo
26 Apr 2020 18:44
I will address your questions in more detail, especially regarding cleaning and surface care for Malm furniture:
1. Felt pads: Yes, these do provide protection but tend to collect dust and often small sand particles. It’s recommended to tap off the felt pads every few weeks and gently clean them with a brush if needed. This helps prevent scratches caused by abrasive particles.
2. Cleaning agents: For Malm furniture, which usually has a melamine-coated surface, plain water with a soft cloth is often sufficient. Alternatively, a mild dish soap solution (a few drops in warm water) can be used, but avoid harsh cleaners, abrasive products, or anything containing alcohol!
3. Surface polish: If you wish, you can use special furniture polish or furniture wax suitable for melamine surfaces. However, make sure it does not contain silicone, as this can damage the finish over time.
In general: The more chemical agents you use, the greater the risk of adversely affecting the finish. So it’s best to proceed gently and minimally.
I hope this helps!
