ᐅ How can I protect Malm dressers from scratches?
Created on: 30 Aug 2020 16:34
Ledara
Ledara
30 Aug 2020 16:34
Hello everyone, I have several Malm dressers from IKEA and want to protect them from scratches. The problem is that I often place small items on them, which can easily damage the surface. Therefore, my question is: What methods or products do you recommend to effectively protect Malm dressers from scratches without significantly changing the look or feel of the furniture? I am thinking of protective films, glass tops, or special coatings but am unsure which option works best in the long term. Thanks in advance for your advice!
Gilbert
30 Aug 2020 16:49
Ledara schrieb:
Which methods or products would you recommend to effectively protect Malm dressers from scratches without significantly altering the appearance or feel of the furniture?
Honestly: Most protective films are either barely noticeable or make the furniture look cheap. Better to use a glass top! It offers reliable protection and is easy to clean. You lose very little aesthetically if you choose a clear one. Avoid varnishes or coatings, as they often don’t last long and repairing them can be tedious.
WARREN
30 Aug 2020 17:12
Glass protective panels are practical and effective. Alternatively, felt pads are recommended under decorative items.
EDWARD0
30 Aug 2020 17:22
There are scratch-resistant coatings, but they require professional application. For home use, glass or self-adhesive protective film is more practical.
Ledara
31 Aug 2020 08:57
Thanks for the quick responses! The glass top sounds appealing since I’d like to keep the surface visible. But what about the weight and stability? Does such a top fit well on a Malm dresser, or is it prone to slipping? Are there any experiences with this? Also, do scratches appear on the dresser itself if small items are regularly placed on it, even when they have felt pads attached?
GU-LAU60
31 Aug 2020 09:41
A glass panel won’t slip if it has enough weight. You can attach small rubber pads to the dresser to increase grip and prevent slipping. Felt pads under objects help, but they don’t completely prevent scratches, especially with heavier items.
