ᐅ How can discoloration be prevented on Malm furniture?
Created on: 8 Apr 2020 07:23
Cemli
Cemli
8 Apr 2020 07:23
Hello everyone, I have a question about "How to prevent discoloration on Malm furniture?" and I hope to get some helpful tips from you here.
I own several IKEA Malm furniture pieces, which are quite sensitive to discoloration due to their light-colored surface, for example from makeup, pens, or even water stains. Although I am very careful, some unpleasant yellowish to brownish spots have already appeared in certain areas.
I am particularly interested in which preventive measures and regular care products you would recommend to keep the furniture looking true to color and stain-free for as long as possible. Are there any special cleaning agents, protective films, or surface treatments that provide good protection against such discoloration?
I am also open to sharing experiences about what did not help or even made the discoloration worse in your case.
Thank you very much for your advice!
Edric
8 Apr 2020 09:07
I can really understand how frustrating it is when Malm furniture gets stains, even though you’re careful. Especially with light-colored surfaces, it can feel quite helpless once the discoloration appears.
One thing I’ve learned is to clean regularly, but not too aggressively. I often use a damp cloth with a bit of mild dish soap and wipe it dry immediately afterward. Sometimes, scrubbing too hard has actually caused more damage because the surface becomes roughened and then stains set in more quickly.
I’m curious to see what others recommend, as I don’t find it that easy to get it right :-)
hauklo
8 Apr 2020 09:46
To prevent discoloration on Malm furniture, I recommend the following measures:
1. Immediately remove any liquids and stains, as the surface is usually coated with melamine resin, which is scratch-resistant but can be prone to discoloration when exposed to fats and dyes for extended periods.
2. Use a mild, pH-neutral cleaning agent and avoid ammonia-containing or harsh solutions.
3. Protect heavily used areas, such as countertops or dressing tables, with covers or transparent protective films.
4. Clean regularly with a soft cloth to remove dust and dirt that could damage the surface.
5. These pieces of furniture do not come with any special sealing treatment; additional surface treatments are possible in principle but should always be tested first on an inconspicuous area.
It is important to avoid aggressive chemicals, as they can damage the melamine coating and make the furniture more susceptible to wear.
lalutau
8 Apr 2020 10:15
In addition to the previous tips, I would like to add the following point:
The frequent discolorations are not only caused by the melamine-coated surface but often also by insufficient cleaning or prolonged contact with color-releasing substances.
I also recommend using microfiber cloths for cleaning, as they are less abrasive than coarse sponges or rags.
If slight discolorations have already appeared, you can try gently removing the stains with a furniture eraser – but be very careful and always test in an inconspicuous area first!
In general, the lifespan and visual preservation of Malm furniture require a combination of prompt response to soiling and proper care.
pilous
8 Apr 2020 11:02
Edric schrieb:
Sometimes I have caused more damage by scrubbing too hard
This seems like an important point, as the surface of Malm furniture cannot be compared to that of solid wood furniture.
Rather, the surfaces are often coated with plastic and are therefore scratch-resistant but vulnerable to chemical and mechanical damage.
I would be interested to know if there are any studies or manufacturer recommendations regarding suitable cleaning products.
hauklo schrieb:
Protection through coverings or transparent protective films on heavily used surfaces
That sounds generally reasonable, but which protective films have proven to be durable and visually acceptable? Or does this completely compromise the original look and feel?
rigau
8 Apr 2020 11:44
In short: Avoid aggressive cleaning agents, heat, and wipe immediately; do not leave anything standing on the surface. For dressing tables, placemats or a glass panel are recommended as protection.
