Hello everyone, I recently bought Malm furniture from IKEA, specifically dressers and nightstands, and I noticed that the surfaces and edges are quite prone to scratches and minor damages. My question is: What are some proven methods to effectively prevent damage to Malm furniture? I am interested in tips for everyday protection, during assembly and setup, as well as for cleaning and maintenance. Any advice on the best way to handle the materials would also be very helpful, as I am unsure whether special care products or protective films are useful. Thanks for your experiences and suggestions!
Hey ONPAR41, that’s a nice, precise question, which makes the discussion a lot easier! 🙂
I’ve had particularly good experiences using felt pads under the legs of my Malm dressers and also underneath items placed on the surface. This helps prevent small movements from causing scratches.
It’s also worth considering a transparent protective film for the surfaces—a kind of “invisible bodyguard” for your furniture. If you have children or pets in the house, this can save you a lot of trouble and scratches. 😉
For cleaning, I usually use a microfiber cloth with some lukewarm water and avoid harsh cleaning agents that could damage the finish.
Basically, I recommend minimizing mechanical stress on Malm furniture, which mainly consists of particleboard with a melamine coating. This means avoiding direct impacts and not placing heavy or sharp-edged loads on the surfaces.
Additionally, it is important to ensure the furniture is set up on level surfaces to prevent deformation or unstable stresses.
Felt pads and protective covers are advisable for protection.
Cleaning agents should be pH-neutral, free of abrasive components, and contain no solvents to avoid damaging the surface.
I understand very well how frustrating scratches and unsightly damage can be, especially when you want to keep your furniture for a long time.
It might also be helpful to use special protective profiles, particularly on corners and edges, which are known to be especially vulnerable. I don’t own Malm furniture myself, but friends have told me that these transparent corner protectors can be applied quite well, especially if there are small children in the household.
Of course, it is also important to choose cleaning products carefully. Personally, I tend to be cautious with harsh cleaners because I’m concerned they might dull the surface. Often, a soft cloth and a bit of patience are enough.
Hello everyone, I would like to provide a structured guide on how to largely avoid damage to Malm furniture:
1. Transport and Assembly: When unpacking and assembling, try to work on clean surfaces and keep hard objects away to prevent scratches. Do not overtighten screws to avoid cracking.
2. Surface Protection: Use felt pads under the furniture legs and also under decorative items. These help prevent abrasion.
3. Usage: Avoid placing wet or sticky items directly on the surface, as liquids can damage the coating.
4. Cleaning: Use only soft cloths and mild cleaning agents, if any. It is best to wipe damp and then dry immediately.
5. Protective Films: Especially for Malm furniture, which has relatively sensitive surfaces, self-adhesive transparent films can help prevent scratches and stains.
In summary: Careful handling, targeted protection, and proper maintenance are essential.
Thank you for the tips so far, especially the idea of protective films—I find that very interesting. My question is, does anyone have experience with films specifically marketed for IKEA Malm furniture? Or do universal furniture protective films work just as well?
Also, I’d like to revisit something: What are your thoughts on the load capacity recommendations for Malm furniture—such as when placing heavy items on it? Are there specific limits that should not be exceeded?
