ᐅ How can I prevent damage to IKEA Brimnes furniture during transportation?
Created on: 19 Jul 2023 10:23
britsanHello everyone,
I am planning to move some IKEA Brimnes furniture soon – mainly dressers and wardrobes. My main concern is how to prevent damage during transport as much as possible. The furniture is disassembled, but since the surface is made of coated particleboard, I am worried about scratches, chipping, or other damage that could occur while loading, unloading, or inside the transport vehicle.
Does anyone have experience or specific tips on how to safely transport Brimnes furniture? For example, regarding padding, packaging, transport position, or handling during loading? I want to avoid unnecessary or overly complicated measures and proceed as efficiently and safely as possible. Any advice on useful tools (e.g., special blankets, protective films, or straps) would also be appreciated.
Thank you in advance for any help!
Thierryzar19 Jul 2023 11:07It is best to wrap each part individually in furniture blankets and provide good padding. Straps help secure the furniture in the vehicle. Avoid direct contact between hard surfaces.
To prevent damage during the transport of IKEA Brimnes furniture, I recommend the following approach:
- Transport furniture parts fully disassembled to reduce the gross weight and avoid damage to connectors.
- Protect the pieces with thick moving blankets or specialized furniture covers to prevent damage to the sensitive particleboard surfaces.
- Additionally, cover delicate areas with bubble wrap to prevent scratches and dents.
- Position the parts as flat and securely as possible in the transport vehicle to avoid damage caused by shifting.
- Use tension straps or tie-down straps to secure the furniture parts during the trip.
- Handle loading and unloading with care, especially around edges and corners.
These measures have proven particularly effective in practice. A combination of protective materials and careful securing significantly minimizes potential damage.
Blavin schrieb:
Cover delicate surfaces additionally with bubble wrap to prevent scratches and dents.May I critically ask whether bubble wrap is always the best option? In some cases, the wrap can stick to the furniture or peel off the coating when removed, especially with strong adhesive effects.
Wouldn’t it be more practical to use a combination of a pure furniture blanket and some cardboard as an extra buffer at sensitive spots?
Furthermore, the type of transport vehicle is important – a moving company with experience and clean, non-slip loading surfaces can drastically reduce risks, which is not always the case with private moves.
Are there any experiences here on whether certain methods more often lead to damage in practice, despite theoretical protective measures? I am questioning this because some recommendations tend to be accepted without sufficient consideration of all factors.
