ᐅ How do I prepare Ikea BESTA furniture for repainting?
Created on: 14 Nov 2021 08:17
Da_mau49
Da_mau49
14 Nov 2021 08:17
I am planning to repaint my IKEA Besta furniture because the surface no longer looks good after several years of use. I am wondering how to best prepare these pieces for repainting so that the new finish adheres well and stays attractive for a long time.
I know that Besta parts are usually covered with a film or coating, so I want to avoid paint peeling or unevenness later on. What are the important steps for surface preparation? Is light sanding enough, or do I need to sand the entire surface thoroughly, possibly prime it, or use special adhesion promoters? Are there any specific tips for working with this type of surface, which often consists of particleboard with a film or melamine coating?
I look forward to your experiences and recommendations, as I want to do it right to achieve a lasting result.
naujon
14 Nov 2021 09:42
Hello Da_mau49,
Your question is very well phrased, as the preparation is crucial for achieving a durable finish, especially with IKEA BESTA furniture. Here is a structured guide that I have developed:
- First, you need to thoroughly clean the surface. It works best with a degreasing cleaner to remove all dirt and oils.
- Since BESTA furniture often has a melamine or laminate coating, simply sanding with fine sandpaper is not enough. You should sand the surface well with 120 to 180 grit sandpaper to ensure the new paint adheres properly. This is important because the smooth laminate otherwise significantly reduces adhesion.
- Next, it is advisable to use a primer or adhesion promoter that is specifically designed for smooth surfaces. There are special products made exactly for plastic or melamine surfaces.
- After priming, you can lightly sand the surface again (for example, with 220 grit sandpaper) to help the paint adhere better.
- Then you can apply the finish in thin layers. An acrylic paint or a furniture-specific paint is recommended.
Common mistakes I see are insufficient sanding or skipping the priming step. In those cases, the paint often peels off quite quickly.
I hope this helps! If you have any more questions or details about the type of paint or your furniture, feel free to share.
Domau0
15 Nov 2021 11:29
naujon schrieb:
Since BESTA furniture is often coated with a melamine or foil surface, simply sanding lightly with fine sandpaper is not sufficient.
That sums up the issue very well.
I would like to add that the exact surface of IKEA BESTA units can vary: some surfaces are covered with a thin melamine foil, others may have a plastic-coated particleboard, or even painted fronts. Depending on this, the preparation needs to be adjusted.
Here is my detailed process:
- Disassemble the furniture: An important tip is to separate the doors and fronts from the carcasses if possible. This way, you can access all surfaces better and work more precisely.
- Sand the surface: For melamine or foil coatings, you should definitely roughen the surface using a sanding pad or sandpaper with a grit of 120 to 180, but avoid sanding through the coating. The goal is only to scuff the surface slightly, not to expose the substrate.
- Apply adhesion primer: Since these foils are often difficult to paint, I recommend using special adhesion promoters for plastics, such as two-component primers or plastic primers that ensure the paint adheres well.
- Intermediate sanding: After drying, lightly sand with about 220 grit sandpaper to create a smooth surface.
- Painting: It’s best to use a multi-component or acrylic furniture paint. Spray painting is worth considering for a very even and durable finish.
- Let dry and protect: If you want to be extra safe, you can apply a clear topcoat as a protective layer.
Important note: When sanding, be careful not to round off or damage the edges. The edges of BESTA elements are often sensitive.
How have you approached this so far, and what materials are you working with? That could help provide a more precise answer.
TAUPLO
16 Nov 2021 14:53
Da_mau49 schrieb:
What are the important steps for preparation? Is simply sanding enough, or do I need to sand the entire surface, possibly prime it, or use special adhesion promoters?
Hi,
to keep it short and clear: No, just sanding isn’t enough, because the surface of BESTA furniture is often quite smooth, and smooth stays smooth – paint doesn’t like that very much. So here’s my practical tip, with a little wink 😉:
- First, clean thoroughly, or you won’t get good results with your new paint.
- Then sand properly with 180-grit sandpaper until the surface feels noticeably rough – but don’t overdo it, or you’ll see the scratches later.
- Apply a bonding primer – this basically ensures your paint will stick properly.
- After that, you can start painting, ideally with several thin coats.
Pro tip: If you want, you can add a protective topcoat afterward, for example clear lacquer – your BESTA will thank you and shine like new!
Hope this helps you out without confusion! Enjoy your project!
