ᐅ How can I permanently fix loose screws in IKEA Metod kitchen cabinets?
Created on: 8 Jun 2024 10:13
HaulenHello everyone, I am currently facing the following issue: In my IKEA Metod kitchen, screws keep coming loose on certain cabinets despite normal use. The screws often sit loosely, causing wobbly parts, and I want to fix this problem permanently.
Does anyone have experience with especially reliable methods to secure loose screws in Metod cabinet units long-term? Which tools or materials work best, and are there practical tips on how to protect the wood or the fastenings themselves from further wear?
I would like to find a solution that truly lasts and ideally doesn’t leave any unsightly repair marks. Thanks for your advice!
Hello Haulen!
This sounds like a common issue with many Metod kitchens, since the material is often just 16mm (0.6 inches) particleboard, and the screw holes can widen over time.
My trick: If the screw is already loose in the wood, you can try filling the hole first with wood glue and then with small wooden dowels or toothpick pieces. Once it’s dried, you can screw it back in—a kind of mini wood upgrade for your furniture! 😄
If you want to be on the safe side, use a screw with a larger diameter or a special furniture connector screw beforehand. And remember: always screw in carefully to avoid making it worse.
Good luck, you’ll get it fixed!
For a permanent repair of loose screws in IKEA Metod kitchens, applying wood glue into the worn-out screw hole has proven effective. Using toothpicks or wooden sticks soaked in wood glue and inserted into the hole ensures a solid connection once it has dried. If needed, a screw with a larger diameter can be used, but it should not be too thick to avoid further weakening the material.
Alternatively, two-component adhesive can also be used to achieve a stable bond. It is always important to clean and dry the material thoroughly before repair to ensure proper adhesion.
I also recommend using high-quality screws, possibly with integrated threads designed for furniture panels. Regularly checking the fastenings helps prevent recurring issues.
Hey Haulen, I had exactly the same problem, and after trying wood glue and toothpicks, I mainly relied on the tip about using larger screws – that really works! 😍 Especially with Metod kitchens, you can make small improvements that make a big difference.
One extra tip from me: Sometimes it helps to replace the screw with a longer one so it gets better grip in the back panel wood. I found that very effective! Just experiment a bit, and soon you’ll have a super stable kitchen, almost like new!
