ᐅ How can I permanently fix loose screws in IKEA Metod kitchen cabinets?
Created on: 8 Jun 2024 10:13
Haulen
Hello everyone, I am currently facing the following issue: In my IKEA Metod kitchen, screws keep coming loose on certain cabinets despite normal use. The screws often sit loosely, causing wobbly parts, and I want to fix this problem permanently.
Does anyone have experience with especially reliable methods to secure loose screws in Metod cabinet units long-term? Which tools or materials work best, and are there practical tips on how to protect the wood or the fastenings themselves from further wear?
I would like to find a solution that truly lasts and ideally doesn’t leave any unsightly repair marks. Thanks for your advice!
I can clearly understand how frustrating it is when screws in the kitchen start to loosen. I experienced the same, especially with frequently used cabinets.
What helped me was being patient during the repair and not applying too much pressure on the screw too quickly. Sometimes it feels overwhelming when it doesn’t hold right away, but with the right technique and suitable materials, it gets better.
It’s also perfectly fine if it takes a few attempts to find the right method for your piece of furniture. Thanks also for the tip about the different screw sizes in the previous post; that really opens up new perspectives.
Wesley schrieb:
My tip: If the screw is already loose in the wood, you can try filling the hole first with wood glue and then small wooden dowels or toothpick pieces. Once it’s dry, you can screw the screw back in – kind of like a mini wood upgrade for your furniture! 😄 Thank you very much for the detailed tip! The “mini wood upgrade” sounds practical. My screws are mostly in the side panels, which are often only 16 cm (6 inches) deep – so I’ll probably cut the dowels as short as possible. What has been your experience with the curing time of wood glue in kitchen furniture? Does it really hold strong over the years? Or do you prefer to use two-component adhesives for long-term stability?
INGRID34 schrieb:
Just put wood glue into the hole, insert toothpicks, wipe off excess glue with a damp cloth, and let it dry. Then screw the screw back in. That’s a nice summary, thanks! If anyone here has advice on the best type of glue for humid environments, that would be great.
Looking forward to more experiences!
Haulen schrieb:
My screws are usually in the side panels, which are often only 16 mm (0.63 inches) deep – so I try to cut the dowels as short as possible.That’s exactly how I do it! The dowels should only be as long as needed to properly fill the screw hole without putting pressure on it, otherwise the material can split.
Regarding glue: letting wood glue cure properly is ideal for long-lasting strength. In a standard kitchen, this works great if you allow it to dry thoroughly and make sure nothing is damp beforehand – moisture significantly weakens the bond!
Two-component adhesives will definitely provide an even stronger bond, but they are harder to adjust if you want to change screws later.
So with wood glue, you have a good chance of lasting years without needing a complicated adhesive.
