ᐅ How can I optimize the installation of Metod kitchen cabinets in older apartment buildings?
Created on: 26 Sep 2018 08:43
naimbau
naimbau
26 Sep 2018 08:43
I am currently facing the challenge of optimizing the installation of Metod kitchen cabinets in an older apartment. My focus is especially on planning and execution in rooms with uneven floors, slanted walls, and often very low ceiling heights. The standard Metod cabinets are generally designed for more rectangular and even rooms, which creates additional difficulties in older buildings.
I am particularly interested in how you deal with these structural challenges to ensure a stable and precise installation. Which tools, techniques, or preparation steps have proven successful for you? It would also be helpful to know if you had to make any modifications to the cabinets or the installation instructions to accommodate the difficult conditions.
I look forward to your tips and experiences on the following topic: How can I optimize the installation of Metod kitchen cabinets in older apartments to ensure the best possible fit and stability despite structural challenges?
FAZAR
26 Sep 2018 10:07
Hello naimbau,
your question is very practical and covers many common issues I have also frequently encountered in older apartments. Installing Metod kitchen cabinets in older buildings indeed requires more preparation than in new constructions, as often uneven floors and slanted walls make installation more challenging.
A proven first step is to take precise measurements of the space using a laser distance meter to capture height and width deviations with millimeter accuracy. Then, I recommend adjusting the base cabinet substructure with leveling feet—that means you can fine-tune each cabinet individually to ensure it stands level.
naimbau schrieb:
The standard Metod cabinets are usually designed for rather rectangular and even rooms
That is an important point, because Metod is only partially flexible. Therefore, you can cut frame profiles or solid wood strips to size for recesses on slanted walls. For example, I often use a mounting profile at the top for tall cabinets, which I then individually adjust to the slope.
It is also important to check the wall’s load-bearing capacity in advance, especially in older buildings. Old plaster or drywall sometimes cannot provide sufficient support, and it is necessary to anchor deep into the masonry.
A small tip: Many underestimate the time needed to adjust the baseboards. You should definitely cut and fit them to size to create visually clean lines.
What tools do you already have available? For such installations, I use, in addition to a standard cordless drill, a small angle grinder for cutting and a multi-tool with a saw blade for precise adjustments.
If you like, we can go into more detail—perhaps with information on how exactly your older building wall looks.
TARAON
26 Sep 2018 11:39
Hi naimbau and FAZAR,
I really like the topic – the combination of ultra-modern Metod cabinets and the charming, sometimes tricky old kitchen is definitely a challenge! ?
FAZAR schrieb:
A proven first step is to precisely measure the room with a laser distance meter to capture height and width deviations down to the millimeter.
Absolutely essential, but I’d like to add: don’t just measure, also visually check for damp or damaged walls – especially in older buildings, otherwise the installation result can be affected by later damage.
Personally, I like to work with a bit of flexibility during installation. For example, if a wall is so slanted that no straight cabinet fits, I rely on adjustable shelves or let the baseboard protrude a few millimeters (inches) so it doesn’t look too bulky.
And here’s a casual tip: when space is tight, always use the small helpers – a level that can be used both horizontally and vertically often proves more useful than the biggest high-tech tools.
It should be fun too, because then you work better. I think your question is really important – old meets new is not something you get with a standard package. Good luck!
figata
27 Sep 2018 07:51
For additional information and a clear overview:
1. Planning
- Accurately record room dimensions, including any unevenness in floors and walls, using appropriate measuring tools.
- Check wall materials (brick, plaster, wood paneling) to select suitable screws and anchors.
2. Adjustment
- Use adjustable leveling feet to achieve precise micro-tilting of base cabinets.
- Customize cabinet corner cuts or fit wooden strips to accommodate sloped surfaces.
3. Installation
- Wall cabinets should be fixed to load-bearing points; pre-drilling into solid walls may be necessary.
- Tailor baseboards to size to ensure a neat appearance and visually compensate for minor irregularities.
4. Inspection
- After installation, verify that cabinet fronts close flush and the floor is level.
- If needed, make adjustments to compensate for varying support surfaces.
Following this structured process optimizes installation even in older buildings without compromising on stability or fit. It is worthwhile to focus on quality accessories (anchors, screws, leveling feet), as these ultimately ensure stability.
