ᐅ How do I mount Ikea Metod wall cabinets on drywall (plasterboard) walls?
Created on: 29 Mar 2018 18:37
KHALED9Hello everyone,
I am planning to mount my Ikea Metod wall cabinets in the kitchen on drywall walls. Since I know that drywall is not as load-bearing as solid walls, I want to choose the best and safest fastening method.
My questions for you:
- Which specific anchors or fasteners are best suited to securely attach the wall cabinets to drywall?
- Are simple expansion anchors sufficient, or are special cavity anchors (such as toggle bolts or metal hollow wall anchors) necessary?
- How can I prevent the cabinets from sagging over time or the screws from pulling out?
- Is it advisable to install additional reinforcements behind the drywall (such as wooden battens), or are there other practical solutions?
I look forward to your experiences and advice, especially if anyone has already tackled similar installation tasks with the Metod system. Thank you in advance for your help!
KHALED9 schrieb:
I’m planning to attach my Ikea Metod wall cabinets in the kitchen to drywallThe question is whether that is actually sensible and safe. Drywall is simply not designed to carry heavy loads, as you can see in many forums.
- You should definitely use hollow wall anchors; they are much stronger than simple expansion anchors.
- If the system is supposed to be truly load-bearing, additional reinforcements behind the wall would, in my opinion, be the better option. Otherwise, you can forget about heavy loading later.
- Alternatively, don’t just drill into drywall but locate or install a load-bearing substructure (for example, a wooden board between the drywall and the wall or studs).
To be honest, I consider attaching large kitchen cabinets to plasterboard to be risky. If you really want to mount on drywall, carefully consider how to distribute and stabilize the load.
But let’s hear what others have to say – maybe someone has the perfect solution.
Some time ago, I also installed Metod wall cabinets on drywall and used the following approach:
- First of all, it’s important to secure the cabinets to load-bearing elements. Drywall panels alone are not strong enough, so you need to locate the wooden studs or metal profiles behind the drywall. You can find them using a stud finder or a magnet.
- Anchors: For drywall areas without studs to attach to, hollow wall anchors like toggle bolts or metal anchors are acceptable if the load is light (e.g., a small cabinet with light contents). For larger cabinets, it’s better not to rely on these.
- Practical tip: Attach a sturdy wooden batten horizontally to the studs, which the cabinets can rest on, and screw the cabinets directly into this batten. This way, the weight is distributed and you have a secure hold.
- If the wall is weak or you cannot find studs: add additional reinforcement, for example a plywood panel behind the drywall, which is fastened to the studs.
- Screws: Use screws with coarse threads for better grip in wood.
In summary: Screwing directly into drywall is not a good idea for heavy wall cabinets. Use the studs for mounting or install a wooden batten as a support. This ensures a very secure installation.
Good luck!
Good luck!
praWarre6930 Mar 2018 10:42KHALED9 schrieb:
Which special anchors or fasteners are best suited to securely attach wall cabinets to drywall?For the small wall magicians, I recommend toggle anchors—they hold well if you don’t overload them. But seriously, the main issue here is the load capacity.
SIAURORA schrieb:
Or you don’t just drill into drywall but find or install a solid substructure (for example, a wooden panel between the drywall and the wall studs or bracing).That’s true—attaching a wooden batten or a plywood panel between the drywall and the wall is a great idea. I simply fastened 40mm (1.6 inches) thick battens horizontally to the studs. Then the cabinets hung securely, and I could focus on other issues. 😁
Oh, and important: distribute the load evenly. Otherwise, all the weight is on a single screw, and that’s the end of it.
And if you like a bit of crafty flair: screw the wall cabinets to the countertop at the bottom if possible, for extra stability.
Good luck and have fun assembling!
