ᐅ How do I mount Ikea Metod kitchen cabinets on different types of walls?
Created on: 29 May 2016 18:42
meleo
meleo
29 May 2016 18:42
Hello everyone, I am currently planning the installation of my new Ikea Metod kitchen and am wondering about the best way to attach the upper kitchen cabinets to different types of walls. Specifically, I’m interested in which anchors, screws, and mounting methods you would recommend for mounting on, for example, a concrete wall, a drywall (plasterboard) wall with a wooden frame, or an old brick wall. What should be considered for the different substrates to ensure the cabinets are securely fixed and do not cause any long-term damage? I’m also curious if additional reinforcements or special techniques are necessary for certain wall types. Thanks in advance for your advice!
letar
29 May 2016 19:05
Basically, when installing Ikea Metod kitchen cabinets, the choice of anchors and screws depends on the wall material.
- Concrete walls: I recommend using high-quality heavy-duty anchors (e.g., metal anchors or high-quality nylon expansion anchors) and correspondingly strong screws. Drill holes must be accurately positioned, with depth and diameter matched to the fastening elements.
- Brick walls: Universal anchors or special brick anchors are suitable; it is important to have good anchoring in solid material. For hollow bricks, cavity anchors should be used.
- Plasterboard (drywall) with timber framing: It is best to screw the cabinets directly into the wooden studs to ensure maximum stability. Otherwise, drywall screws with appropriate cavity anchors can be used, but this is less stable.
Additional reinforcement is only necessary if the weight of the cabinets might exceed the wall’s maximum load capacity or in very old, crumbly walls. It is always important to check the condition of the wall beforehand.
reybo
29 May 2016 20:38
The question is very well posed because the type of wall largely determines the fastening method. I would like to go into more detail here:
1. Concrete wall: It is best to first mark the exact positions of the cabinet hangers. Then drill appropriate holes with a hammer drill – make sure the anchor length is about 10–15 mm (0.4–0.6 inches) longer than the screw to provide sufficient grip. Heavy-duty metal anchors are the safest choice here. Screws should be at least 6 mm (0.24 inches) in diameter. A washer increases the bearing surface and prevents the screw from pulling out.
2. Brick wall: Solid brick walls provide good support for universal anchors, but for hollow bricks, you should definitely use cavity anchors with an expanding mechanism. Prefe drilling with a small drill bit to avoid damaging the cavity.
3. Drywall with wooden framework: First, check with a small nail or a stud finder to locate the wooden studs. Then, the cabinets can be screwed directly into the wooden framework. If that is not possible, I recommend using special drywall metal anchors (e.g. toggle bolts) or heavy-duty cavity anchors.
One final tip: Always use a level when mounting to ensure the upper cabinets are installed straight. The weight and load on the wall should be taken into account, especially when mounting several heavy cabinets. Distributing the fastening loads across multiple points on the wall is advisable.
What type of wall do you have at your home?
mipau
29 May 2016 21:12
For concrete: use heavy-duty anchors.
For bricks: use universal anchors or cavity anchors for hollow bricks.
For drywall: screw into wooden studs, otherwise use special drywall anchors.
Katau
30 May 2016 08:09
Hello! I think it’s great that you are considering the different types of walls separately; that’s really important. For drywall partitions, I recommend always checking before installation whether the wall is stable enough and what the underlying structure looks like.
If you cannot screw directly into wooden studs, I advise against fastening using only drywall screws, as they do not provide sufficient support. Instead, special anchors are needed to distribute the weight, such as toggle bolts or hollow wall anchors. For heavier upper cabinets, adding a second wall reinforcement can help.
Also: always choose the correct screw length and, if possible, use wing nuts on the back side if there is access for backing. Safety comes first.
meleo
30 May 2016 09:41
reybo schrieb:
What type of wall do you have at home exactly?
Thank you for the detailed response, reybo! My kitchen wall is an old brick wall, about 40cm (16 inches) thick and very solid. However, in the adjoining rooms, I partly have drywall partitions, which I want to use for additional cabinets. It’s important to me to be absolutely sure with the brick wall since the cabinets do weigh quite a few kilos. How large should the anchors for this brick wall be at a minimum? And do I need a special drill for this as well? Also, I’m wondering if, with the drywall, I have to first expose or locate the wooden stud framework or if a special type of anchor will hold reliably without issues?
