ᐅ How can I make Ikea Besta doors and drawers close quietly and smoothly?
Created on: 21 Jan 2017 18:13
nemu67
nemu67
21 Jan 2017 18:13
I have an Ikea Besta shelving unit with doors and drawers, but unfortunately, they close quite loudly and with a bit of a bang. I would like to adjust or equip them so they close quietly and smoothly, essentially adding some kind of damping to the closing process. I’m particularly interested in what options are available:
- Are there special dampers that can be retrofitted?
- Can the existing hinges or drawer slides be adjusted to allow for a softer closing?
- What experiences have you had with different systems or modifications?
I would prefer to avoid expensive complete replacement solutions and instead work with targeted measures. Maybe you also have tips on what to pay attention to during installation to achieve the best possible smoothness. Thanks in advance!
deoke
21 Jan 2017 19:07
Hello nemu67,
a very well-formulated question! To make your Ikea Besta doors and drawers close quietly and smoothly, there are several approaches I’d like to explain systematically.
First, it is important to know the type of hinges you have. Besta usually uses simple pivot or press-in hinges without a soft-close feature. You can replace these with soft-close hinges that have an integrated damping mechanism. This is the most effective solution.
If you don’t want to replace the hinges, there are so-called clip-on dampers you can attach. These damping units are glued to the cabinet side or onto the hinge and slow down the door closing. Precise alignment during installation is crucial so the dampers work properly and don’t activate too early or too late. Using a small angle gauge or templates can help with this.
For the drawers, it’s similar: if they come without soft-close slides, you can replace the slides with soft-close versions or add special dampers (e.g., small silicone or rubber buffers) that slow down the closing impact.
One important point to note is the adjustment of the hinges. Often, loud closing is due to incorrect adjustment, for example, if the door isn’t perfectly aligned or the closing angle is too wide, causing the door to slam into the frame. The 3D adjustment options on Ikea hinges usually help with fine-tuning this.
Summary:
- Retrofit soft-close hinges
- Attach clip-on dampers with adhesive pads
- Use drawer slides with soft-close function
- Adjust hinges for precise alignment
A quick note: When installing, pay close attention to the exact position of the dampers, otherwise their effect may be minimal or uneven.
A quick question: Do you have the option to replace the hinges completely, or is that too complicated for you? Then I could recommend more specific models.
TARNE
21 Jan 2017 20:44
Hey nemu67!
I totally understand how annoying loud doors and drawers can be, especially when you already have a nice piece of furniture. I solved this myself with my Besta shelf, and now it feels like a completely different piece—really classy when everything closes softly! 😊
I added small soft-close retrofit dampers to my hinges—it was a bit tricky at first, but once they’re properly in place, the effect is amazing! You just need a small screwdriver, a measuring tape, and a little patience.
If you want, I can write you a step-by-step guide on how I did it! Just let me know, and I’ll get started. I think it’s really worth it, and we’re not talking about a big investment, more like a small DIY project that significantly improves your furniture!
So: Don’t be afraid to do it yourself—you can do it! Best regards!
BLAKEO
21 Jan 2017 21:56
deoke schrieb:
If you don’t want to replace the hinges, you can install so-called adhesive dampers. These damping units are glued onto the cabinet side or directly onto the hinge and reduce the impact of doors slamming shut.
That sounds promising at first, but how durable are these adhesive dampers in everyday use? I mean, does the glue hold up over time? And what happens if the door is slammed harder – can the dampers withstand that repeatedly without failing?
I’m asking because I’m somewhat skeptical that such a simple adhesive solution will work long-term with daily multiple uses in a living room setting. Does anyone have solid experience with this? Or are there similar methods that are mechanically more stable?
Also, how do they look aesthetically – does such a damper stand out visually and disrupt the overall appearance of the furniture?
I think it’s important to carefully consider whether it might be better to install soft-close hinges right away – even though that involves a bit more effort.
Franklin36
22 Jan 2017 07:31
Good morning everyone,
I would like to add a few structured tips from my experience—especially since I have worked on Ikea Besta furniture several times:
1. Retrofitting soft-close hinges: Ikea offers an affordable soft-close hinge set that is relatively easy to install. It is important to loosen the screws on the old hinges, attach the soft-close module, and then adjust the doors.
2. Smooth drawers – there are two options here: either buy complete drawer slides with damping or install so-called impact dampers as small silicone/rubber buffers inside the track area.
3. Adjustment: A common mistake is that the doors are not properly aligned. Especially with Besta, the hinges are 3D adjustable (height, side, and depth). It’s worth taking the time to adjust the doors precisely both horizontally and vertically.
4. Retrofitting dampers: Adhesive dampers work well under moderate use; for heavy use, I recommend mechanical solutions such as full soft-close hinges or drawer slides.
5. Installation tips: Loosen screws, don’t remove them completely, this makes it easier to fine-tune the doors. Always pay attention to the recommended distance and position when using clip-on dampers!
Conclusion: Soft closing isn’t complicated but requires precise work and good components. I recommend replacing hinges with soft-close versions if possible. However, if cost or effort is limited, a clip-on damper is often sufficient.
One more tip: Before purchasing, take exact measurements of the hinges or slides, as not all soft-close modules fit Besta.
If anyone is interested, I can also share a list of recommended products I have personally tested.
Tekuko
22 Jan 2017 11:48
Replacing soft-close hinges is usually the cleanest solution.
Alternatively, attach soft-close dampers if the load is not too heavy.
Adjust the hinges properly to prevent the door from slamming.
For drawers: install soft-close slides or silicone bumpers.
This works easily without major modifications.
